Thread: Which alternator do you have?
Results 1 to 11 of 11
  1. #1 Which alternator do you have?
    GXP Level Member
    Mar 2015
    Tomball
    So there are 2 different alternators I see for 04+ cars. One is the standard old alternator with a nut in the center of the pulley and the other is the "clutched" alternator it has a cover over the center of the pulley. I have noticed that looking at different websites that 04' always shows a clutched alternator and 05' always shows a standard alternator. 06' and later seem to waffle on wether or not it's equipped with an overrunning clutch or a standard fixed pulley system. So which do you have? Have you replaced, or has it been replaced in the past. I'm not asking because I want to know which is better, pros and cons or anything else. All I'm trying to figure out is what year is equipped with what.
    Thanks,
    Jeff
  2. #2 Re: Which alternator do you have?
    hangover park IL
    my 04 compG and my 04 gtp clone both had the clutch. one dieded via a screeching sound from the clutch slipping, the other had a wavering screech/clack as it released/locked
    both are gone, replaced with vintage horizontal bolt brackets and horizontal bolt cs 144 alternators
    ~James~ Psychotic Gearhead
  3. #3 Re: Which alternator do you have?
    Nov 2012
    Madison
    04 compg
  4. #4 Which alternator do you have?
    Old style.. Which was rebuilt and powder coated (04)
    But then I eventually had problems with it and Matt (Booba) convinced me to go the CS 144 route
    04 Comp G.
  5. #5 Re: Which alternator do you have?
    GXP Level Member
    Mar 2015
    Tomball
    It's starting to look like all the 04's come with the clutched alternators. Anyone have an 06+ with one or came with one?
    Jeff
  6. #6 Re: Which alternator do you have?
    Enfield, CT
    Remind me to check 2morrow lol
    Sent from my LG G3
  7. #7 Re: Which alternator do you have?
    hangover park IL
    Gm figured out that the clutches weren't worth the NVH complaints.
    And much like the 04/05 only LCA'S/sway bar links....gm went back to a proven design
  8. #8 Re: Which alternator do you have?
    Dec 2013
    Enfield
    My 04 Comp G has the clutch style as well.
  9. #9 Re: Which alternator do you have?
    Feb 2016
    Woodbridge
    Not sure what was in there (was OEM, sold it to the scrap yard last year) before I swapped out for https://www.dcpowerinc.com/fit/Ponti...93-250-xp.html
    Scored it used on Ebay 5 or so years ago. I bought it for my audio system in my 2005 GP. My 230XP must be a discontinued model..I don't see it listed on their website anymore, at least for the GP anyway.
    You can see the custom wiring I did to accommodate the extra juice. It is welding cable. Hammered, punched and soldered the copper lugs on and put some heat shrink on the ends. I still need to taper the ends to the starter as it is crowded down there with the bigger lugs.
    Which alternator do you have? Attached Images
    Last edited by Hempire; 02-23-2016 at 01:19 PM. Reason: add info about custom wiring
  10. #10 Re: Which alternator do you have?
    GXP Level Member
    Mar 2015
    Tomball
    That's cool I am really not concerned with aftermarket or custom alternators I am trying to figure out when the clutched alternator was used. Looks like 04' is the only one, although I spoke with someone that had an 06 with one.
    Thanks
    Jeff
  11. #11 Re: Which alternator do you have?
    Feb 2016
    Woodbridge
    Love the fan on pulley design Red. Very nice. Sorry Jeff, I'd go look at mine too but it's gone!
  1. Alternator
    By scott198283 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-03-2016, 04:35 PM
  2. Do I need a new alternator?
    By 00Daytona in forum General Grand Prix Discussion
    Last Post: 12-02-2015, 11:27 PM
  3. Alternator...maybe?
    By Booba5185 in forum General Tech Discussion
    Last Post: 01-11-2014, 11:33 PM
  4. Will this alternator fit my 02 gp gt?
    By thegipper in forum General Tech Discussion
    Last Post: 10-03-2011, 06:06 PM
  5. HO Alternator
    By kissmyss in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-02-2009, 08:48 PM
