Thread: Wanted modified fuel rails, fuel logs, and a braided fuel line setup.
Results 21 to 40 of 41
  1. #21 Re: Wanted modified fuel rails, fuel logs, and a braided fuel line setup.
    you can see all the spots that touch on the blower here, no paint on the clip on the snout, the vac manifold tree and bbv both are shinny where they rub, and the point of the tb next to the vac manny
  2. #22 Re: Wanted modified fuel rails, fuel logs, and a braided fuel line setup.
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Sounds like you need some cradle spacers!
    Well see how it goes if no one on here comes up with a good ic setup I'll probably just screw it and go the cam route or a ssic and a cam.
    Sent from my LG-H901 using Tapatalk
  3. #23 Re: Wanted modified fuel rails, fuel logs, and a braided fuel line setup.
    now why would i open up another can of worms and fuk up my axle geometry? lol
  4. #24 Re: Wanted modified fuel rails, fuel logs, and a braided fuel line setup.
    Oct 2015
    Idk lol I'd assume 3/16" or however thick they are really wouldn't make any difference
  5. #25 Re: Wanted modified fuel rails, fuel logs, and a braided fuel line setup.
    if the metal was being touched, id do something about it, its just in the foam liner so not giving a crap about it at all.
  6. #26 Re: Wanted modified fuel rails, fuel logs, and a braided fuel line setup.
    Oct 2015
    Ya I wouldn't give a crap either lol
    Question though I'm just really trying to mod and don't really care how. I was thinking about getting a meth kit, but if I'm running e85 would the meth kit be a waste considering e85 basically does the same thing as meth?
  7. #27 Re: Wanted modified fuel rails, fuel logs, and a braided fuel line setup.
    no meth if you got e85. try some NOS out to put on top of the e85 lol
    i just got a meth kit, should be here next week. cant wait to drop a pulley and jack up my timing. im stuck on 93 here.
    e85 and a ic does work well together as well.
  8. #28 Re: Wanted modified fuel rails, fuel logs, and a braided fuel line setup.
    Oct 2015
    Ya I didnt think meth and e85 was a good idea. I'm thinking about just getting a ssic now if I can't find a fsic on here. I think I really need to do a cam though since I'm peaking at about 10lbs of boost in 50ยฐ weather on a 3.4 pulley. I feel like most people are running 8lbs on a 3.4
  9. #29 Re: Wanted modified fuel rails, fuel logs, and a braided fuel line setup.
    3.4 gets you to about 10 to 12. mine did.
    now a ported lim with a ic and a 3.2 will drop you to 8 or 9 psi. bout what im at with the l36 bottom end.
  10. #30 Re: Wanted modified fuel rails, fuel logs, and a braided fuel line setup.
    Oct 2015
    I thought the ic would increase boost pressure since its a restriction? I also have an l36 bottom end.
  11. #31 Re: Wanted modified fuel rails, fuel logs, and a braided fuel line setup.
    with my mod list in my sig with no ic and the stock pulley i made 6 psi, jumped right to the fsic and a 3.2 only see 9 ish. i got a 2.8 and 3.0 to play with once the meth kit gets installed
    the ported lim is what lowers the psi.
  12. #32 Re: Wanted modified fuel rails, fuel logs, and a braided fuel line setup.
    Oct 2015
    Well **** I'll go port my lim right meow if it'll bleed off 1-2lbs if boost lol. I feel like it probably has a lot to do with your head porting. I really wish i would have ported my heads before I topswapped, I was just a noob back in those days though and had no idea how to. Its crazy how much I've learned to do in the past year thanks to this car.
  13. #33 Re: Wanted modified fuel rails, fuel logs, and a braided fuel line setup.
    ive heard normal top swaps w/ stock pulleys make 7-8 psi, so the rockers and heads do help some for sure.
    stock pulley with headers and the rockers on my l67 left me at 5 psi. so im guessing the high compression is adding a psi or two over the l67.
  14. #34 Re: Wanted modified fuel rails, fuel logs, and a braided fuel line setup.
    Oct 2015
    Ya I was at about 6.5 on a stock pulley, headers, and 1.9s
  15. #35 Re: Wanted modified fuel rails, fuel logs, and a braided fuel line setup.
    them rub holes as i should say.
  16. #36 Re: Wanted modified fuel rails, fuel logs, and a braided fuel line setup.
    Oct 2015
    I do concur with you Scotty! This thread can be closed as well I mad the commitment to go the cam route. By the way does anyone know who grinds intenses camshaft. There a guy selling a brand new one But the specs on the cam paper he showed me were slightly off so I'm trying to figure out how I can tell for sure it's an s1x
  17. #37 Re: Wanted modified fuel rails, fuel logs, and a braided fuel line setup.
    Oct 2015
    It says it's made by cam motion?
  18. #38 Re: Wanted modified fuel rails, fuel logs, and a braided fuel line setup.
    you still wont get much past a 3.4 with just a cam, ic and cams are perfect together. or that corn...
  19. #39 Re: Wanted modified fuel rails, fuel logs, and a braided fuel line setup.
    Oct 2015
    But im already on the corn lol
  20. #40 Re: Wanted modified fuel rails, fuel logs, and a braided fuel line setup.
    theres a guy here with a cam, ported heads, fsic, 80 injectors with corn, and a 75 shot of NOS. gen 5 and a 2.6 pulley and lots o boost lol
    hes still on the old stock tranny and takes it to 120 at min on his way to and from work daily he tells me lol
    he had the ic before the corn swap went down, he kept it on there and it seems to help still, hes at 22ยบ wot timing too. not a hint of kr.
  1. Replies: 0
    Last Post: 09-01-2016, 09:37 PM
  2. WTB: modded fuel rails or fuel logs (L67 return-style)
    By 97AutoXVette in forum Wanted To Buy - Parts
    Last Post: 04-20-2016, 02:43 PM
  3. Delete
    By AjL227 in forum Wanted To Trade
    Last Post: 08-04-2015, 11:42 AM
  4. Wanted Modified L67 Rails or Fuel Logs.
    By sseilmnop in forum Wanted To Buy - Parts
    Last Post: 05-29-2014, 01:07 PM
  5. Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    By Iron Indian in forum How To Write-Ups/Tech Tips
    Last Post: 01-17-2009, 07:53 PM
