Thread: Chrome or Black Headlight Housings
Results 1 to 6 of 6
  1. #1 Chrome or Black Headlight Housings
    May 2015
    Pennsylvania
    I have a 2001 Pontiac Grand Prix GT (White). I installed Spyder Clear Led Tail lights. I want to replace the stock headlights with another stock pair. What would look better, black housings with clear lenses or chrome housings with clear lenses? I figure black housings will go with the black grill. If I got the chrome housings I would get a silver grill. Can't afford retrofits at the moment so getting stock head lights for now.
  2. #2 Re: Chrome or Black Headlight Housings
    St. Louis
    I would say chrome on the headlights just due to the fact that even stock they suck, so why black out the housing thus creating even less light output (if that's possible). Stick a set of Eagle Eye stock replacements in it and call it a day, then save up for some retro's. Just my .02
  3. #3 Re: Chrome or Black Headlight Housings
    GT Level Member Hardonyomom's Avatar
    aurora
    Here is my experience. I tried the black housings because they don't indeed look much cooler. The problem is that the stock headlights are TERRIBLE!!! They are impossible to see out of at night compared to the chrome housings. The solution was to get HID fogs and HID headlights. Problem solved and i am still using black housings.
    F body Front, GXP rear brakes, SSC, Poly Dogbones, SLP Gen 1 spoiler, Gpo's, GTX hood, SD Air dam, LED tails, badges and decals, Comp G Seats,
    FSIC, Ported and painted Gen 3, ZZP LIM, SD Headers, REmoddified ZZP fuel rail, 60 lb injectors, LS7 lifters, 1.9 modded rockers, 2.6 pulley E85, 21 degrees timing -Timboku tuned
  4. #4 Re: Chrome or Black Headlight Housings
    GTX Level Member SomeDudeAtHome's Avatar
    Buffalo, NY
    Black look better but like they've said the light output is worse on them. Think about how much night driving you do and then decide on if it's worth it. I used HIDs in the black housings for about 3 months while planning a retrofit and other drivers hated me. I was constantly getting flashed and I aimed them as best I could. Black lights on a white are do look awesome though.
    Black 98 GT bought in summer of 2009 w/28K miles- GTX Rims, Retrofit headlights, tinted tails, 20% tint all around, KYB Excel-G's, WBS Lowering Springs, 33mm Dorman front sway bar, 22mm Addco rear sway bar, BMR trailing arms, BMR STBs front and rear, ZZP control arms, Poly motor mounts, ZZP CAI, Thrasher shift kit
  5. #5 Re: Chrome or Black Headlight Housings
    Dec 2008
    Lawndale, CA
    The ebay black headlights have a smaller chrome reflector. That is why the light output is so poor. If you want black headlights it is best to find a chrome set that has the same size reflector as OEM, open them up and paint the smooth area black. The light output will be the same as stock since the reflector is the same size.
  6. #6 Re: Chrome or Black Headlight Housings
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by fitness94 View Post
    Stock headlights and clear corners go together.
    Black headlights and black corners go together.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  1. Are all Black Crystal style headlight housings created equal?
    By OldFart in forum Visual/Body Modifications
    Last Post: 05-07-2013, 04:16 PM
