Thread: Spyder Tail Lights Installation
Results 1 to 5 of 5
  1. #1 Spyder Tail Lights Installation
    May 2015
    Pennsylvania
    I recently purchased Spyder Led tail lights for my 2001 Pontiac Grand Prix GT. Went to install them and the drivers side won't push in all the way and there is a space. What do I need to do? Thanks.
  2. #2 Re: Spyder Tail Lights Installation
    GT Level Member Hardonyomom's Avatar
    aurora
    honestly, there are not the best fitting. You just have to push them in all the way and put the plastic ring on the other end realllllllyl tight and they will fit in there. trust me!
    It's also very important that you hook the black wire up to the black wire like the sticker said or they won't work properly. This is just for the middle plug. It still uses the turn signal and backup bulbs though. H
    Hope this helps
    F body Front, GXP rear brakes, SSC, Poly Dogbones, SLP Gen 1 spoiler, Gpo's, GTX hood, SD Air dam, LED tails, badges and decals, Comp G Seats,
    FSIC, Ported and painted Gen 3, ZZP LIM, SD Headers, REmoddified ZZP fuel rail, 60 lb injectors, LS7 lifters, 1.9 modded rockers, 2.6 pulley E85, 21 degrees timing -Timboku tuned
  3. #3 Re: Spyder Tail Lights Installation
    May 2015
    Pennsylvania
    The top corner also won't fit well.
  4. #4 Re: Spyder Tail Lights Installation
    Antioch, IL
    Some installs need to have the bolt holes on the car enlarged with a file, other than that, plug n play
    2009 Challenger SRT8
    Expert at being gay.
  5. #5 Re: Spyder Tail Lights Installation
    May 2015
    Pennsylvania
    I got them installed and they look great. Thanks for the advice.
  1. Spyder ccfl halo headlight installation questions
    By Tyarne15 in forum Visual/Body Modifications
    Last Post: 03-01-2015, 02:57 PM
  2. WTB Spyder Red/Smoked LED Tail Lights
    By MattF in forum Wanted To Buy - Parts
    Last Post: 04-29-2013, 10:46 PM
  3. opinions on spyder tail lights
    By Matt Palm in forum Visual/Body Modifications
    Last Post: 03-24-2012, 03:05 PM
