Thread: led turn signals and side markers
Results 1 to 11 of 11
  1. #1 led turn signals and side markers
    Feb 2015
    il
    I have a 01grand prix and im trying to install the led bulbs for the front. I am getting the "hyperflashing" with the converters installed. Can anyone help with this issue?
  2. #2 Re: led turn signals and side markers
    May 2012
    Where winter never ends
    Pretty sure you just need load resistors installed but im not an expert on this.
    2000 Regal - Winter Beater
  3. #3 Re: led turn signals and side markers
    Banned
    Jan 2013
    Colorado
    load resistors would be a cheap fix, replacing the relay with a high flash relay would be a better option.
  4. #4 Re: led turn signals and side markers
    Dec 2012
    Where 4T65E's were born
    Get yourself an LED compatible signal flasher. Part #: EP28
    Can be bought at advance auto parts, amazon, etc.
    It's under the drivers kick panel, next to the steering column. It costs around $13-$15
    Sold.
  5. #5 Re: led turn signals and side markers
    May 2012
    That works as well.
    Load Resistors or the flasher deal work well
  6. #6 Re: led turn signals and side markers
    Jul 2010
    Coquitlam,BC,Canada
    Get the EP28. No need to hack up the wiring if you don't need to.
    http://chrisb.users.superford.org/Gr...r_Corners.html
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  7. #7 Re: led turn signals and side markers
    SE Level Member illtacticz's Avatar
    Dec 2010
    Columbus, Ohio
    Will the EP28 work on the 2008 Grand Prix 6Clydr?
  8. #8 Re: led turn signals and side markers
    Enfield, CT
    Quote Originally Posted by illtacticz View Post
    no. will not work for 04+.
  9. #9 Re: led turn signals and side markers
    Dec 2010
    Columbus, Ohio
    So only other option is resistor in this case i presume?
  10. #10 Re: led turn signals and side markers
    Feb 2015
    il
    Quote Originally Posted by tyty0594 View Post
    Sorry i ment "with the resistors installed". So yes i had the resisitors installed and i still got huperflash so i was thinking. Bigger resistors? Do the side markers have to be hooked up with the trun signals some how because they flash with turn signals? And i also forgot to mention but the green dash arrow stays solid as well??
  11. #11 Re: led turn signals and side markers
    Jul 2010
    Coquitlam,BC,Canada
    Read the link I posted.
    Or get Canbus bulbs.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  1. High beams turn on intermittently when using turn signals
    By Boomersooner in forum General Tech Discussion
    Last Post: 01-13-2012, 08:31 PM
  2. 04+ clear side markers (cant find)
    By zx7r4u2nv in forum Visual/Body Modifications
    Last Post: 03-01-2011, 01:29 AM
  3. turn signals.
    By Koniig in forum Visual/Body Modifications
    Last Post: 11-17-2010, 08:41 AM
  4. Turn Signals
    By brett88 in forum General Tech Discussion
    Last Post: 10-03-2009, 07:21 PM
