Thread: A Custom Retrofit
Page 4 of 4 FirstFirst ... 234
Results 61 to 73 of 73
  1. #61 Re: A Custom Retrofit
    Not bad.. Can't beat $25 projectors or at least that's what I think the rx are running in the close out section.
    04 Comp G.
  2. #62 Re: A Custom Retrofit
    GTX Level Member xxpappas13xx's Avatar
    Aug 2011
    Michigan
    These were only the generic on his, I picked up the generic and the rx's on closeout for me!
  3. #63 A Custom Retrofit
    Plz your not ready for them lol. I use to have some rx330 non afs but eventually sold them. Thought about getting the close out afs but ehh I don't wanna do quads.
    04 Comp G.
  4. #64 Re: A Custom Retrofit
    Aug 2011
    Michigan
    Got to learn somehow! But dont have to do quads, just put the rx in low beam and use halogen high beam!
  5. #65 Re: A Custom Retrofit
    Or just throw in the set of FXR I had sitting on my shelf for awhile now lol.. bam no need for halogen high beam.
    04 Comp G.
  6. #66 Re: A Custom Retrofit
    Aug 2011
    Michigan
    That always works too! I wired Brandon's to have the halogen high beam and the mini h1 high beam when the solenoid moves
  7. #67 Re: A Custom Retrofit
    Honestly I don't think I ever used my halogen high beams even in my old retros, high beam was never needed.
    04 Comp G.
  8. #68 Re: A Custom Retrofit
    Aug 2011
    Michigan
    Here is a before and after on his car!
  9. #69 Re: A Custom Retrofit
    Aug 2011
    Michigan
    Done done done! One projector fell it was hitting the plastic behind the headlight and hitting bumps made it fall, so I trimmed that more. They are aimed way better on the 3rd attempt and the iron man is wired!
    Had to adjust the left down a little
    The money shot of them 100% correct!
    And iron man
  10. #70 Re: A Custom Retrofit
    Aug 2011
    Michigan
    Picked up some more parts for my build! Generic clear lenses, 5500k D2s motimoto bulbs, 70mm and 80mm xsb halos, and few other free goodies from TRS black Friday sale.
    Comparison of the clear lens vs stock lens of rx-afs projectors and orange passive demon eye
    Sent from my SM-N910V using Tapatalk
  11. #71 Re: A Custom Retrofit
    Aug 2011
    Michigan
    Still not done. Aimed up a little bit because that's how they fit with having to trim so much. Since there is no reflectors, there is no adjustment on these, and then used acrylic to have something to mount too.
  12. #72 Re: A Custom Retrofit
    Aug 2011
    Michigan
    Finally compete! Not perfect like others, but happy with the results.
  13. #73 Re: A Custom Retrofit
    Mar 2014
    A2 MI
    How did you do the clear corners and what size halo is on the mini
    Sent from my SM-N920T using Tapatalk
  1. Looking for 99 GTP custom bumper cover and custom hood
    By Gojin54 in forum Shops and Community Heroes
    Last Post: 06-28-2013, 02:39 PM
  2. Is this all I'll need for a retrofit?
    By SomeDudeAtHome in forum Visual/Body Modifications
    Last Post: 05-21-2013, 10:49 AM
