Thread: Help! Removing waterspots from inside headlight?
Results 1 to 9 of 9
  1. #1 Help! Removing waterspots from inside headlight?
    SE Level Member Daven's Avatar
    Apr 2014
    Saskatchewan, Canada
    I was restoring my headlights and forgot to make sure to not get water inside. I drained what I could out and dried to blowdry it but when it dried they now have waterspots on the inside of the lense. Really a pissoff since I finally got the lense crystal clear :/
    Does anybody know of a way I can remove these? Maybe mixing amonia-free windex and trying the same thing? :/
    Using Tapatalk
  2. #2 Re: Help! Removing waterspots from inside headlight?
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Put some distilled water on a small cloth and attach to something bendy and try to clean it off. Like a pipe cleaner, windex might work. Might aswell try.
    Sent from my Galaxy Tab 3 8.0
    2012 F150 STX
    - Gonna be a race truck
  3. #3 Re: Help! Removing waterspots from inside headlight?
    Apr 2014
    I don't know of anything I could use to reach around in there. These are 07 headlights. I tried with a butter knife and dry rag but I get no reach and it the one chamber is blocked for the headlight cover chrome thing (?). Maybe I need to deal with it :/ bit it's a lot of spots and I'm a perfectionist when it comes to my car
    Using Tapatalk
  4. #4 Re: Help! Removing waterspots from inside headlight?
    Well worse case stock replacements are like $80-100
    04 Comp G.
  5. #5 Re: Help! Removing waterspots from inside headlight?
    Apr 2012
    Dayton, OH
    If all else fails you could crack them open and clean them, or buy new ones. Bendy metal should be able to reach around but I haven't examined 04+ headlights up close before so idk.
    2012 F150 STX
  6. #6 Re: Help! Removing waterspots from inside headlight?
    Apr 2014
    What am I looking at to take apart and reseal them? I was debating trying to switch out the reflectors to clear ones so maybe I could do that and clean then. But i have been worried about getting them to seal good again after
    Using Tapatalk
  7. #7 Re: Help! Removing waterspots from inside headlight?
    Baking them in the oven long enough to weaken the butyl and then prying them apart with a flathead or such.. If they're oem headlights don't bother they'll be permasealed which is a b**ch to get open and cleaned up.
    04 Comp G.
  8. #8 Re: Help! Removing waterspots from inside headlight?
    Apr 2014
    Yep they're OEM. Tomorow I'm going to try jet dry and distilled water. Hopefully that works
    Using Tapatalk
  9. #9 Help! Removing waterspots from inside headlight?
    Apr 2014
    Ok so good news! Went and picked up some "Finish" brand rinse agent (the better on plastics one) and two 8L jugs of distilled water. Didn't measure out anything, but I sloshed around some rinse agent along with distilled water. Then rinsed it with the water until the bubbles were gone. Don't shake, the bubbles will never go away. Just slosh around and tip over to drain. Shook the light out the best I could, then hit it with the blow dryer with the holes pointed up to vent. It appears to have worked and the inside water spots are gone!
    Again, the inside of my headlight wasn't dirty to begin with, just had hard water spots. So I wouldn't take this method to try and clean badly hazed headlights. But hopefully this can help somebody else who glitches out like me when cleaning their lights lol thanks for the response guys!
    Using Tapatalk
  1. Removing A/C condensor without removing radiator?
    By 97AutoXVette in forum General Tech Discussion
    Last Post: 04-02-2014, 07:43 AM
  2. Best material inside hid headlight
    By dengnath in forum Visual/Body Modifications
    Last Post: 09-10-2011, 10:17 AM
  3. Two Morimoto projectors one cup...uh...I mean headlight...headlight
    By RedDawnGXP in forum Visual/Body Modifications
    Last Post: 03-23-2011, 05:07 PM
  4. 04+ removing headlight lens from assembly
    By Piggy in forum Visual/Body Modifications
    Last Post: 07-27-2010, 04:10 AM
  5. Removing/cleaning headlight and side marker lenses
    By bronzemist02 in forum General Tech Discussion
    Last Post: 01-04-2010, 08:45 PM
