Thread: GE Nighthawk platinum bulbs which ones ?
Results 1 to 3 of 3
  1. #1 GE Nighthawk platinum bulbs which ones ?
    GXP Level Member ryangtp89's Avatar
    Maine
    I decided to go with the GE nighthawk platinum's over the ultra stars since they don't last long for my 04 impala SS. I wanted to know what bulbs I needed for the headlights. it says low beam is 9006 and high is 9005, does that mean I need to buy 4 bulbs for the headlights ? Also I want them for my foglights which are 893's but I don't see them anywhere.
    SLP headers, Wizaird cai, zzp1.0pcm ,slp powerflo catback, 3.4mps, NGK TR55's, 180*, zzp stage 1 hv tb,tb spacer, tb heatshield, Triple Edge Performance High performance Tranny, flipped motor mounts, spring blockers, prj 10.4mm wires, Sloted rotors & Ceramic brake pads,Alternator Voltage Booster. zzp 1.9 rockers & 105# springs
  2. #2 Re: GE Nighthawk platinum bulbs which ones ?
    Dec 2008
    Lawndale, CA
    Yes the car uses 4 bulbs. If you use your hugh beams a lot then upgrade them. If not just get the lows. You may want to get HIR's instead (not to be confused with HID's).
  3. #3 GE Nighthawk platinum bulbs which ones ?
    LaBarge Supercharged sseilmnop's Avatar
    Mercer, Pa
    Look up 9011 and 9012 hir bulbs. You have to trim one tab with side cutters. Easy, brighter, whiter and longer life then stock. Get from amazon.
    To my knowledge there isn't a replacement or upgrade bulb for fog lights.
    Adapters, Phenolic Intercoolers, Supercharger Parts & TVS2300
    http://stores.ebay.com/QualitySuperchargers
  1. replacing 194 bulbs with LED bulbs
    By abc in forum Audio, Security & Visual Electronics
    Last Post: 02-02-2014, 01:22 PM
  2. Platinum Plugs vs. Iridium Plugs
    By Eddie Jackson in forum 5.3L V8 (LS4)
    Last Post: 10-17-2012, 10:55 AM
  3. boch platinum-V-ac delco
    By nfb93 in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-02-2009, 01:13 PM
