Thread: Seeing the road
Page 1 of 7 123 ... LastLast
Results 1 to 20 of 122
  1. #1 Seeing the road
    Mar 2013
    Philadelphia
    So the same as everyone else, my stock headlights suck. And I know that everyone here is going to tell me to retrofit, but I just don't have the time until summer comes around. So to be able to see for the time being what should I look into? HIDs? Better quality halogen bulbs? Thanks.
  2. #2 Re: Seeing the road
    Florida
    Retrofit.
    Are the lenses all cloudy and yellowed, or is their moisture in them? If so, replace them.
    HID's in a normal housing, while bright, don't offer the best usable light, and are also illegal, and dangerous to other drivers.
    The Silverstar Ultra's are pretty good Halogen bulbs, but wont be anything compared to HID. (could always buy a Retrofit from someone on the forums)
  3. #3 Re: Seeing the road
    Mar 2013
    Philadelphia
    I really do want to do retros but I lack 2 important things right now: time and money. My lenses are so-so right now. And I have heard all the illegal/dangerous to other drivers talk about HID headlights that is why I am asking if it's worth it. Would HID fogs make a difference at all?
  4. #4 Re: Seeing the road
    wet sand your head lights with like 1000 grit to 1500 to 2000, then buff with rubbing compound, they clear up real nice once the haze is cut off them.
  5. #5 Re: Seeing the road
    Nov 2012
    Madison
    Quote Originally Posted by TNTtransam View Post
    Well considering the cost of Ultrastars and DDM HIDs for example....the better $ deal per lumans would be HIDs.
    If anybody would be glaring its the guys in the trucks with HIDs in reflectors(there is a lot of them) and that never seems to bother me.
    They look at mine(DDM 6k) like they have something unique and all I can think is ..come on man your glaring
  6. #6 Re: Seeing the road
    Mar 2013
    Philadelphia
    So that and better halogen bulbs would be sufficient for a few months?
  7. #7 Re: Seeing the road
    it should help some if the headlights are hazed over. you can sand out scratches and nicks too if you spend the time.
    a pc buffer or similar makes buffing them back to clear real easy, it can be done by hand but it takes some elbow grease.
  8. #8 Re: Seeing the road
    Mar 2013
    Philadelphia
    Alright I'll probably give this a shot. If I go the HID route, is there anything I need to know?
  9. #9 Re: Seeing the road
    Jul 2012
    Chicago
    That oncoming traffic will hate you, and you should feel bad. :P
    -Carl
  10. #10 Re: Seeing the road
    Mar 2013
    Philadelphia
    Quote Originally Posted by nos4blood70 View Post
    Hahaha i m really not trying to look like the douchebag kid racer but my light output is so bad, I m desperate.
  11. #11 Re: Seeing the road
    Florida
    Then sand and polish the lenses and go from there. It's less about people thinking your a kid racer, and more of them being blinded. Also make sure they are aimed correctly.
  12. #12 Re: Seeing the road
    Mar 2013
    Philadelphia
    Alright maybe next weekend if the weather is nice I will do that. Thanks for the help guys.
  13. #13 Re: Seeing the road
    Florida
    Yep, remember to WET sand the lenses, or you can scratch them up. Work your way up from 1000 to 2000 or so, then use a good rubbing compound. The compound will really bring out the shine.
  14. #14 Re: Seeing the road
    Jun 2012
    Ontario Canada
    Mine were really weathered and cracked, so i used 80 grit on them (by hand), then sprayed some carb cleaner on them, it ate around 1/16 inch of plastic off them and i scraped it away with a putty knife, then sanded with 100, 200, 600, 800, 1500 and polished, look crystal clear now and cost about $10
  15. #15 Re: Seeing the road
    Pennsylvania, USA
    Get some Phillips HIR2 bulbs, trim the bases, and pop them in. That is if you have 04+ with separate low's and high's. The HIR2's got me along pretty well until I got retrofits. Hell, I still have them in the high's, same ones I bought two years ago. Those plus the Morimoto's flipping up for the high's make for some ridiculous output. Quad high's ftw.
    And the trick with cleaning up stock clouded headlights is adding a UV coating when you're done cleaning up the fog. The cloudiness is oxidation caused my the UV rays from the sun, so if you don't put a UV coating on after you clean them up they'll be back like that in a year or two. That's why it tends to start up top where the most light hits the headlights.
  16. #16 Re: Seeing the road
    Mar 2013
    Philadelphia
    Bumping this thread for a follow up question. Phillips xtreme power bulbs, yay or nay?
  17. #17 Re: Seeing the road
    Nov 2011
    NY
    I run 50w Retrofit Soruce HID's in new stock housings and never been flashed, never been pulled over. It's all about doing it right. There's a write up on how to make sure you set it up correctly so the HID lamp is positioned properly, search... Lol
  18. #18 Re: Seeing the road
    Dec 2008
    Lawndale, CA
    I ran these for awhile until one went out. I am not using their xtreme vision. They are a good bulb. Better than silverstars. I also have a relay harness so the bulbs get full voltage to them.
  19. #19 Re: Seeing the road
    Mar 2013
    Philadelphia
    Quote Originally Posted by The Guz View Post
    So do you think these bulbs and new clean housings would be sufficient light output?
  20. #20 Re: Seeing the road
    Mar 2013
    Philadelphia
    Or by that point should I just get HIDs for stock housings?
  1. On the Road Again
    By hollilynn in forum General Grand Prix Discussion
    Last Post: 12-15-2013, 05:37 PM
  2. Almost road worthy again!
    By Truckin2001 in forum General Grand Prix Discussion
    Last Post: 03-10-2012, 08:16 PM
  3. Didnt know this was down the road
    By shawnschuldt in forum Off Topic Discussion
    Last Post: 07-19-2011, 12:41 PM
  4. What to do about the really caked on road grime and road salt?
    By s1795so2 in forum Detailing Tips and Tricks
    Last Post: 12-09-2010, 06:55 PM
  5. almost got ran off the road... wtf
    By 2000GTP in forum The Rant Forum
    Last Post: 07-29-2009, 09:20 AM
