Thread: Cleaning Calipers before Paint?
Results 1 to 10 of 10
  1. #1 Cleaning Calipers before Paint?
    GT Level Member Points70's Avatar
    Nov 2010
    Bellevue, Nebraska, United States
    Hey guys, I used caliper cleaner last time before I painted my calipers with Duplicolor High temp Caliper Kit but they still cracked. Do you guys recommend using anything specific to help get some of the grime off of the caliper to help the paint last longer, also while keeping them on the car? I dont really have time or money to take the calipers off, since this is my daily driver. Thanks!
  2. #2 Re: Cleaning Calipers before Paint?
    Sep 2011
    MI
    I just used brake clean & a wire brush then primered it and then paint. Did it a year ago and they still look good.
  3. #3 Re: Cleaning Calipers before Paint?
    Nov 2010
    Ok, I didnt prime mine last time. Any particular Primer?
  4. #4 Re: Cleaning Calipers before Paint?
    i used brake cleaner, sand paper, more brake cleaner, then right before i was ready to paint them, i hung them up with wire, and sprayed them with duplicolor prep spray, after that, its hands off. your fingers leave oil behind and makes the paint turn out crappy.
    then sprayed 5 light coats of vht caliper paint. they still look good a year later. if you got the time, let them sit a day or so to full cure.
  5. #5 Re: Cleaning Calipers before Paint?
    new britain, ct
    brake cleaner works well.
    i didnt sand or do any of that. it came out alright. i didnt take my calipers off either, i just taped off the rotors and sprayed the calipers haha
    07 Black GXP.
  6. #6 Re: Cleaning Calipers before Paint?
    Nov 2010
    Alright, Thanks for the advice! Ill have to sand them because they look like they are covered in grease
  7. #7 Re: Cleaning Calipers before Paint?
    dont sand grease, de grease them, then brake cleaner, if the old paint looks rough, sand them some. then prep and spray.
    i had F bodys to put on, so i hung them up and painted them, the rears i took off, lined the wheel wheel with news paper, then hung the caliper from the strut spring, and sprayed them. let them dry for a few hours, then slide them back on.
    i give you caliper peaches lol they are hanging in a peach tree.
  8. #8 Re: Cleaning Calipers before Paint?
    new britain, ct
    "painted calipers in a peach tree"
    a photo, by scottydoggs.
    07 Black GXP.
  9. #9 Re: Cleaning Calipers before Paint?
    Sep 2011
    MI
    Quote Originally Posted by Points70 View Post
    I try and usualy use the same brand primer as the paint i'm going to spray.
  10. #10 Re: Cleaning Calipers before Paint?
    Nov 2010
    Quote Originally Posted by 99PontiacGTP View Post
    Yeah that actually makes sense
  1. Replies: 6
    Last Post: 07-02-2012, 07:01 PM
  2. Where do you go to get paint for calipers
    By LTeezy in forum Brakes/Suspension/Chassis
    Last Post: 06-19-2012, 10:21 PM
  3. Can you paint calipers (using G2) while on the car?
    By nickbuol in forum Visual/Body Modifications
    Last Post: 08-10-2009, 04:20 PM
  4. Brake calipers and why you choose to paint them?
    By GR8racingfool in forum Visual/Body Modifications
    Last Post: 08-20-2008, 03:57 PM
