Thread: comp g wheel coating?
Results 1 to 17 of 17
  1. #1 comp g wheel coating?
    SE Level Member MissLexx's Avatar
    Apr 2013
    Brookings, SD
    im getting ready to powdercoat the wheels on my 05 gtp comp g. i notice the wheels have a dark grey coating on the inside of the spokes. is this painted on? also does the rest of the wheel have any clear or protective coatings? just want to check everything before i dive in. i would blast them but we are having issues with our blaster
    05' GTP Comp G "pretty in pink"
    00' GT w/ gtp top swap
  2. #2 Re: comp g wheel coating?
    Banned
    Jan 2013
    the bandwagon follower aka noobiee
    wannna coat my wheel
  3. #3 Re: comp g wheel coating?
    Banned
    Jan 2013
    yes it paint
  4. #4 Re: comp g wheel coating?
    Apr 2013
    Brookings, SD
    somebody want to decode that for me??
  5. #5 Re: comp g wheel coating?
    Pennsylvania
    Yeah, the wheel's painted, and the spokes are clear coated.
  6. #6 Re: comp g wheel coating?
    ... osiris94ej's Avatar
    Sep 2012
    Casper Wyoming
    Good luck in removing the paint... Been there and doing that now. Aircraft stripper works but slow process. Sand Blaster at my shop isnt working well either and barely works. Gm used some real paint.
  7. #7 Re: comp g wheel coating?
    Apr 2013
    Brookings, SD
    Thanks, i will brush on some stripper and let it sit and then get after it with the sandblaster.
  8. #8 Re: comp g wheel coating?
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    Quote Originally Posted by importisland13 View Post
    He is in South Dakota, you are in New York. Are you going to pay shipping on four wheels?
    GPONA #1 Cyber Bully
  9. #9 Re: comp g wheel coating?
    Apr 2013
    Brookings, SD
    SHE is in South Dakota :P and you ship it and we'll coat it
  10. #10 Re: comp g wheel coating?
    Omaha, NE
    I would put it in your PC oven without coating it for as long as it takes to cure the wheel. If the paint doesn't flake, peel, etc. just PC over the paint.
    If that makes sense...
  11. #11 Re: comp g wheel coating?
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    Rule 30: There are no girls on the internet.
    Back OT. If you are having them done at a pro shop, they should have a sand blaster. If you are doing it yourself, get a disk ginder with a flap wheel and go to town.
  12. #12 Re: comp g wheel coating?
    Omaha, NE
    Quote Originally Posted by blackspike2710 View Post
    I see your rule 30 and raise you a rule 34.
  13. #13 Re: comp g wheel coating?
    Apr 2013
    Brookings, SD
    I hate to coat over an existing coating if i can avoid it. As long as the existing coating is strong it shouldn't be a problem. We have a flapper wheel but its not fun to try to get between the spokes. I think ile hit it with some stripper and try to blast them. Our compressor is in a temporary location without an adequate dryer and im getting alot of moisture in the sand making it a real pain to blast.
  14. #14 Re: comp g wheel coating?
    Omaha, NE
    There's always hand sanding. I've done it before and it took about an hour per wheel. That being said, about 3 years later my engine enamel is still on there like the day I sprayed it.
  15. #15 Re: comp g wheel coating?
    Apr 2013
    Brookings, SD
    yuck! We are powder coating the rims on the roommates cts-v but making him do the prep work and hes been hand sanding them. Luckily i get to skip out on that party
  16. #16 Re: comp g wheel coating?
    Banned
    Jan 2013
    yeah I would ship them wannna see her past work first =]
  17. #17 Re: comp g wheel coating?
    Apr 2013
    Brookings, SD
    like us on facebook! "No Coast Custom Coatings" some good examples of past work on there
  1. Powder coating
    By natethegreat in forum Visual/Body Modifications
    Last Post: 02-09-2012, 08:46 PM
  2. will meth eat sc coating
    By copperpacecar in forum General Tech Discussion
    Last Post: 09-26-2010, 03:16 PM
