Thread: How to remove the clips for the lower door molding retainer strip?
Results 1 to 7 of 7
  1. #1 How to remove the clips for the lower door molding retainer strip?
    Feb 2013
    Kennewick, WA
    I'm stripping down a door to have it painted and I can't figure out how to remove these clips without destroying them.
    It's like a rivet type clip that holds the metal lower door molding retaining strip.
    I'd pop them from the back but I don't want to destroy the block of sound deading foam glued to the inside of the door.
    Any tricks?
  2. #2 Re: How to remove the clips for the lower door molding retainer strip?
    It's Slow LS1GTP's Avatar
    Sep 2012
    Clarkston, MI
    Just paint over them. Like you said, they are riveted in place. I'd assume that would involve drilling those rivets out, which means you will need a rivet gun to put them back in place. It's all going to be covered by the molding anyway.
    I had some scrap doors, I was trying to remove those and just broke them.
  3. #3 Re: How to remove the clips for the lower door molding retainer strip?
    Feb 2013
    Kennewick, WA
    Thanks. I just left the piece on there.. No big deal if it gets painted over I guess.
  4. #4 Re: How to remove the clips for the lower door molding retainer strip?
    Feb 2013
    Kennewick, WA
    My body and paint guy must be a miracle worker..
    I dropped it off with the piece on there and he gave it back with the clips removed and undamaged.
    New shiny white door is hung and loaded with parts.
    Before
    After
  5. #5 Re: How to remove the clips for the lower door molding retainer strip?
    GTP Level Member
    springfield IL
    You're missing some molding trim their bud....
  6. #6 Re: How to remove the clips for the lower door molding retainer strip?
    GT Level Member UCF04GPGTPCompG's Avatar
    Nov 2009
    Clermont, Florida, USA
    Looks like you got a different door, or he took parts off and didn't put them on again.
    2004 Pontiac Grand Prix GTP Competition Group (250K)
    Engine Mods: K&N Air Intake, ZZP 3'' Downpipe w/MagnaFlow Cat
  7. #7 Re: How to remove the clips for the lower door molding retainer strip?
    Feb 2013
    Kennewick, WA
    I finally got all the old mounting tape off the original white trim pieces and got them mounted this weekend..
    It's all back together now.
    The door was replaced.. I got a nice black one off a 97 GP at a local yard and had it painted white.
    Cost was a little more than I planned for .. In the end I could have gone to Portland and picked up a white door for about the same cost and much less work (door+gas+food)
    I re-used the OE white trim, door handle, mirror, plus a few other bits.
    Hinges, brackets, latch, and regulator were from the 97 door.. The originals were all bent.
  1. 2k8 Lower side molding clips - need part number
    By mscheuler in forum General Tech Discussion
    Last Post: 11-09-2011, 07:18 PM
  2. GTP lower door moulding clips
    By Regalgs98 in forum General Tech Discussion
    Last Post: 03-22-2011, 11:09 AM
  3. fixing lower door molding thing...
    By 2000GTP in forum Visual/Body Modifications
    Last Post: 03-14-2009, 06:13 AM
  4. Passenger door lower molding
    By dwm1975 in forum General Tech Discussion
    Last Post: 08-13-2008, 05:04 PM
