Thread: Paint match?
Results 1 to 6 of 6
AAclinard Paint match? 01-03-2013, 04:04 AM
Explicit_Spade Re: Paint match? 01-03-2013, 04:42 AM
AAclinard Re: Paint match? 01-03-2013, 04:46 AM
Explicit_Spade Re: Paint match? 01-03-2013, 04:58 AM
AAclinard Re: Paint match? 01-03-2013, 05:12 AM
Matt Palm Re: Paint match? 01-03-2013, 09:33 AM
  1. #1 Paint match?
    Jan 2013
    Crystal Lake, IL
    This might be a newb question, but I do need an answer.
    I just got my 2004 GT2, and it's the stock Storm Gray color. The first visual thing I'd like to do is paint the engine cover, and I'd like the base color of that to match the body color. I was wondering if anyone knows if there are any good automotive spray paints that match this color, or if I really need to take it to a shop. And if I do take it to a shop, does anyone know about how much they cost for basic services, along the lines of color matching, minor scratch touch ups, interior plastic color, and some other minor things. I've never had to use a place like that so I honestly have no idea if I'm looking at 50-60 bucks or thousands.
    Thanks!
  2. #2 Re: Paint match?
    Omaha, NE
    "Storm Gray" was not a color name in 2004.
    Your paint code should be found in one of two RPO code locations:
    1) RPO #2 Inside Trunk Deck Lid
    2) RPO #1 Spare Tire Cover
    Here's a list of 2004 Grand Prix color code info.
    Chip Color Code(s) Color Description
    12, 519F, WA519F Galaxy Silver Metallic
    15, 929L, WA929L Cashmere Metallic
    32, 648H, WA648H Dark Otter Metallic
    40, 8554, WA8554 White
    41, 8555, WA8555 Black
    47, 9539, WA9539 Medium Green Metallic
    56, 913L, WA913L Sunburst Orange II Metallic
    63, 817K, WA817K Sport Red Metallic
    812K, 88, WA812K Medium Spiral Gray Metallic
    You can even order directly from here: Pontiac Paint Code Locations | Touch Up Paint | AutomotiveTouchup | 888-710-5192
  3. #3 Re: Paint match?
    Jan 2013
    Crystal Lake, IL
    U 812K. Medium Spiral gray. Thanks so much!
  4. #4 Re: Paint match?
    Omaha, NE
    No problem, since you're planning on doing the engine cover, Krylon Fusion would make a good inexpensive base, and help smooth out some of the dimples.
  5. #5 Re: Paint match?
    Jan 2013
    Crystal Lake, IL
    Awesome, thanks. The guy I bought the car from prayed the whole engine cover a flat black. Do I need to sand off his work first, or should I be fine to just prime and paint over that?
  6. #6 Re: Paint match?
    antioch ill
    Just sand a little with 600 grit wipe down with acetone and your set
  1. Transmission Match Ups
    By Matthew Mericle in forum Introductions/Noob Questions
    Last Post: 10-27-2012, 07:05 AM
  2. paint code/perfect match
    By Baileyracing in forum Off Topic Discussion
    Last Post: 07-24-2012, 10:27 PM
  3. Replies: 6
    Last Post: 07-02-2012, 07:01 PM
  4. Speedo & HUD don't match
    By Whitephxaz in forum General Tech Discussion
    Last Post: 08-13-2011, 03:55 PM
  5. Touchup Paint Match?
    By Mark99GT in forum General Tech Discussion
    Last Post: 02-26-2010, 02:50 AM
