Thread: Switchbacks...
Results 1 to 14 of 14
  1. #1 Switchbacks...
    GTX Level Member HVACgtp's Avatar
    Oct 2012
    South Jersey
    My question is can you use a 10ohm 50watt load resistor for the turns? Or is the 6ohm required?
    2001 Silver GT; K&N Intake, 2.5in catback to flowmaster 40's, custom tune, led tails drag wheels and halos......SOLD
    2004 Silver GTP - its got some stuff http://www.grandprixforums.net/deja-vu-71112.html
  2. #2 Re: Switchbacks...
    get an LED flasher relay.
    hacking apart harnesses and adding resistors is dumb.
  3. #3 Re: Switchbacks...
    Oct 2012
    South Jersey
    To this day haven't found one for our cars, unless I'm dupid, and that happens a lot haha
  4. #4 Re: Switchbacks...
    what do you need, en EP28?
    i dont remember which ones these cars come with.
  5. #5 Re: Switchbacks...
    Oct 2012
    South Jersey
    After doing some research there isn't flasher relay, it's controlled by the bcm. No one anywhere has the load resister needed for the turns I got, so after calling around my tint shop that does hids had load resistors they use for hid kits, they are 4.7 ohm and 50 watts. The ones sold are 6 ohm, but after installing the hid set the turns worked flawlessly. If anyone needs a pair call your local accessory shop and see if they have any. They come with the ballast plug wired in, all you have to do is cut the plug off and use the wires!
  6. #6 Re: Switchbacks...
  7. #7
    Quincy, Mass
    In pretty sure there were some switchbacks made that didn't require the flasher to be changed.
    But ya you get an ep29 flasher I think and cut off the middle tab. It might be the 28 I don't remember.
    No more GP 04 Impala SS Indy:
  8. #8 Re: Switchbacks...
    Dec 2012
    St. Paul
    i've been reading about this too a bunch. i came across the same problem. idk if the signals are controlled by the bcm or by a flash module. if it is a flash module, can it be changed rather than putting in a resister parallel to the bulb or if its the bcm, it should be able to be reprogrammed to not have hyperflashing when you change your turn signal to a switchback. gonna be making a few stops at the gm store and asking some questions after Christmas.
  9. #9 Re: Switchbacks...
    Oct 2012
    South Jersey
    After looking around I just went with the resistors, you can use a flasher module I THINK but I couldn't find which one. So I used the resistors
  10. #10 Re: Switchbacks...
    GTP Level Member simbah's Avatar
    Lala land
    04 and newer GP's DO NOT have a flasher relay. The flash is controlled by The BCM, and it cannot be reprogrammed.
    'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others
  11. #11 Re: Switchbacks...
    Dec 2012
    St. Paul
    Quote Originally Posted by simbah View Post
    even by a dealership or anything like that? if so thats retarded......
  12. #12 Re: Switchbacks...
    Oct 2012
    South Jersey
    An HA! So I was right lol. You can tell it is because when I put the bulbs and resistors in it flashed fast and once it sensed the resistance it slowed the flasher down
  13. #13 Re: Switchbacks...
  14. #14 Re: Switchbacks...
    Oct 2012
    South Jersey
    Ahhh senior, but in my sig I have sold said 01 And since purchased said 04 in sig! Haha just messing with you
  1. Lighting: LED switchbacks / Fogs (07 GP)
    By cody116 in forum Visual/Body Modifications
    Last Post: 05-08-2011, 11:54 AM
  2. Switchbacks Burning Out
    By sdavis11b in forum Visual/Body Modifications
    Last Post: 08-27-2010, 06:14 AM
  3. switchbacks ftw.....
    Last Post: 06-04-2010, 10:19 PM
  4. LED Switchbacks
    By cowgirldani in forum Visual/Body Modifications
    Last Post: 02-13-2010, 04:21 PM
