Thread: Replacing passenger door lock actuator
Results 1 to 17 of 17
  1. #1 Replacing passenger door lock actuator
    It's Slow LS1GTP's Avatar
    Sep 2012
    Clarkston, MI
    I have a 2 door GP and when I hit the switch or use the key fob to lock the doors, only the driver side will lock. The passenger side makes the sound you hear when you lock the doors, so it's trying to lock but getting stuck somewhere or the mechanism to lock the door is failing. If I manually flip it to lock, the door is locked just fine and will also unlock like normal.
    I've sprayed the rods with WD40 but that didn't change anything. What could the issue be? Do the lock mechanisms in the door actually go bad?
    This isn't a big deal but if it's something I can fix easily then I'd like to fix it.
    Edit: Pictures are below.
  2. #2 Re: Passenger door unlocks but will not lock with master switch
    Sep 2012
    Clarkston, MI
    Anyone?
  3. #3 Re: Passenger door unlocks but will not lock with master switch
    Sep 2011
    Copperas Cove, TEXAS
    Could be the door actuators/ lock motor or the knob that you push/ pull is binding on the door panel. I have replaced the lock motor in a fox stang with the same problems, but yet in a GP. My driver lock knob likes to bind on the door panel when I unlock it, not when I lock it though...so I have just dealt with it.
  4. #4 Re: Passenger door unlocks but will not lock with master switch
    Sep 2012
    Clarkston, MI
    Hmm I'm not sure which it could be, although it doesn't seem like anything is getting stuck on something else.
  5. #5 Re: Passenger door unlocks but will not lock with master switch
    Sep 2011
    Then most likely a bad lock motor, if going by process of elimination.
  6. #6 Re: Passenger door unlocks but will not lock with master switch
    Sep 2012
    Clarkston, MI
    The doors also unlock by themselves when I open and close a door after washing the car. Kinda weird lol.
    So is it hard to replace the door lock motors?
  7. #7 Re: Passenger door unlocks but will not lock with master switch
    they aren't to bad, you take the inside door skin off, and take the actuator off. its close to the key lock. if you cant see it work the lock, you'll feel it or see it moving. has a linkage bar from it to the lock. just be careful with any of them plastic rings you may have in the linkage. they get old and brittle, and break.
  8. #8 Re: Passenger door unlocks but will not lock with master switch
    Pennsylvania
    It takes all of 5 minutes to get the door panel off and check it out. Dive in homie!
  9. #9 Re: Passenger door unlocks but will not lock with master switch
    Sep 2012
    Clarkston, MI
    I know I know, it's just the fact that it's under freezing temps so it's not worth looking at right now lol. This really is the least of my worries as far as issues are concerned.
  10. #10 Re: Passenger door unlocks but will not lock with master switch
    Sep 2012
    Clarkston, MI
    Well I FINALLY looked into this a little more, since it's one of the last little issues with the car.
    Here are pictures of the door lock actuator, how does it come out?
    Do I just take these 3 bolts out to get the actuator out? (in door jamb)
  11. #11 Re: Replacing passenger door lock actuator
    Sep 2012
    Clarkston, MI
    Still curious.
  12. #12 Re: Replacing passenger door lock actuator
    heres a list of ebay sales for this, looks like the lock its self comes out, and you change it all.
    97 03 PONT GRAND PRIX LEFT FRONT DOOR LOCK ACTUATOR | eBay
  13. #13 Re: Replacing passenger door lock actuator
    Sep 2012
    Clarkston, MI
    Well they also sell these.
    New Dorman Door Lock Actuator Front or Rear Passenger Side Full Size 746 011 | eBay
    I should just pull mine out and find out how this^ comes apart from the latch assembly.
  14. #14 Re: Replacing passenger door lock actuator
    either way it looks like those 3 screws on the outside by the door latch hold the whole lock plate in. after its out you should be able to work on it.
  15. #15 Re: Replacing passenger door lock actuator
    Sep 2012
    Clarkston, MI
    Yea I just wanted a second opinion, I'll dive into it soon.
  16. #16 Re: Replacing passenger door lock actuator
    Sep 2011
    Glad you are tackling this, I have done this on other cars, never a GP though. Seeing how you do it will help me out cause my driver lock is getting slower by the day. So I will be following after you LOL.
  17. #17 Re: Replacing passenger door lock actuator
    Sep 2012
    Clarkston, MI
    Haha alright.
  1. Trunk Switch/ Door Unlock and Lock
    By mainecrab in forum General Tech Discussion
    Last Post: 06-02-2008, 08:58 PM
