Thread: GTP Badge overlays
Results 1 to 11 of 11
  1. #1 GTP Badge overlays
    GT Level Member JesseBranham's Avatar
    Apr 2012
    Myrtle Beach, SC
    So the other day my GTP Emblem fell off. For some reason it will not stay back on my door. I was wondering if the badge overlays are just decals that I could just put in the place of the emblem. Anyone know?
  2. #2 Re: GTP Badge overlays
    GT Level Member 00GT's Avatar
    Dec 2011
    Michigan
    They're usually put on the badges themselves, however you could still put it right on the door if you wanted to. If you want to reattach the badge just get all the old adhesive off and use some 3M double sided tape to reattach it. Should stay on then.
  3. #3 Re: GTP Badge overlays
    SE Level Member 2000gtpbt's Avatar
    Mar 2012
    Alexandria, MN
    3m Double Sided Adhesive Tape is your best bet iv used that my self many times.
    Any man who can drive safely while kissing a pretty girl is simply not giving the kiss the attention it deserves.
    Albert Einstein
  4. #4 Re: GTP Badge overlays
    Apr 2012
    Myrtle Beach, SC
    Well the one that fell off is cracked now.I tried using the 3m tape but it fell off again even though I cleaned it.
  5. #5 Re: GTP Badge overlays
    antioch ill
    i got a badge in my garage if you want
  6. #6 Re: GTP Badge overlays
    Mar 2012
    Alexandria, MN
    There you go, got a non cracked badge and if the tape is not working. You should try to use 3m emblem adhesive in the tube but it can be messy so get some rags with wax and grease remover or water before you start.
    Albert Einstein
  7. #7 Re: GTP Badge overlays
    Just take the other one off for a clean look!
  8. #8 Re: GTP Badge overlays
    Did you use the automotive 3M tape?
  9. #9 Re: GTP Badge overlays
    Apr 2012
    Myrtle Beach, SC
    Quote Originally Posted by boosting98 View Post
    I was thinking of that.
    Quote Originally Posted by slick2500 View Post
    Yes and it just fell off the next day.
  10. #10 Re: GTP Badge overlays
    Sep 2011
    Copperas Cove, TEXAS
    De badge would be best. Nice and clean, let people guess if you have a GT or GTP.
  11. #11 Re: GTP Badge overlays
    Jul 2010
    Coquitlam,BC,Canada
    Proper use of two sided tape...... clean the area with a degreaser (I use brake clean), warm the badge with a heat gun for 5-10 seconds, apply the tape, warm the area you wish to stick the badge to for 5-10 seconds then apply the badge. If it is really cold, warm the applied badge with the heat gun for another 5-10 seconds and put pressure on the badge for another few seconds.
    I have used this method in freezing weather, and to mount HID ballasts upside down. The tape always held as it should.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  1. Badge Overlays
    By MACKEYx11 in forum Detailing Tips and Tricks
    Last Post: 07-12-2011, 05:59 PM
  2. Which GTP overlays?
    By PurpleGuy in forum Visual/Body Modifications
    Last Post: 04-09-2011, 01:03 AM
