Thread: HID Conversion - Any Tips?
Results 1 to 8 of 8
  1. #1 HID Conversion - Any Tips?
    SE Level Member KitRae's Avatar
    Jul 2012
    St. Catharines
    I was thinking of converting to HID Lights. Are there any things that I need to be concerned about? Flickering or any other Errors for the Computer?
    2002 Grand Prix GT 3.8L Naturally Aspirated
    - NGK Iridium Performance Spark Plugs
    - NGK 51031 Performance Spark Plug Wires
    - EPR Cross Drilled Performance Brakes & Ceramic Pads
  2. #2 Re: HID Conversion - Any Tips?
    antioch ill
    get ddm 35w 6000k with the relay harnesses
  3. #3 Re: HID Conversion - Any Tips?
    Jul 2012
    Chicago
    Please don't. You'll be blinding people and not really seeing much better.
    -Carl
  4. #4 Re: HID Conversion - Any Tips?
    GTP Level Member
    Sep 2011
    Motown
    Dont touch the bulb...at all
    Quote Originally Posted by deadwoodspecial View Post
    On a side note, I do want to add that Classy is keeping it classy through all of this. The guy has a hell of a business ethic, and is doing everything possible to make this right. If anyone was, is, or has considered getting retro's, I HIGHLY recommend him. Good prices, and he backs his sh!t.
    GT Level Member chamilton89's Avatar
    Columbus, Ohio, United States
    Quote Originally Posted by Matt Palm View Post
    I second this. I have this setup plus 6k fogs in my GP and love it.
    Infinity all around.
  6. #6 Re: HID Conversion - Any Tips?
    We only have like 50 thread on HID's, go do some searching and reading and you might figure it out.
  7. #7 Re: HID Conversion - Any Tips?
    Donating Users triebenbach07's Avatar
    Dec 2010
    long prairie, mn
    I've had HID's for the last 3 years. They really don't help night time vision at all when installed in the 97-03 housings. I only put them in for appearance. After a 4 hour drive in the dark this last weekend, I decided that I will be upgrading to retrofits, as many before me have recommended.
    If your heart is still set on plain old HID's, I'd suggest getting 9007 harness addapters from ebay. If you have to splice in a resistor like I did, this makes for a nice plug-n-play option for easy reversal.
    2x 9007 HID Conversion Kit Error Free Load Resistors Wiring Harness Adapter ,4C | eBay
    or
    2 PCS Wiring Harness Connector 9004 9007 HB1 FB5 LED Light Bulb Extension Socket | eBay
    good luck
    02 sedan, top swap
  8. #8 Re: HID Conversion - Any Tips?
    GTX Level Member Doug 97 gtp's Avatar
    Sep 2011
    palm harbor florida
    get 35watt vvme 9007 single beam kit for low beams or get the bi xenon for his and lows.
    i have vvme 35watt slim ballast bi xenon 8k for my headlights and vvme 35watt 8k single beam for my fogs. i've had them for about year and have had no problem what so ever.
    1997 GTP . repainted in jet black with blue pearl. rebuilt motor
    with vs cam ported heads and blower.
  1. L36 to L67 TB Conversion? What do I need?
    By ImColeTrickle in forum General Tech Discussion
    Last Post: 02-13-2012, 04:31 PM
  2. Dual tips or trapezoid tips?
    By GTLGDP in forum Visual/Body Modifications
    Last Post: 01-19-2012, 11:42 PM
  3. HID conversion kit?
    By lilbear6889 in forum Visual/Body Modifications
    Last Post: 04-03-2010, 05:19 PM
  4. HID conversion kit
    By Haulero in forum General Tech Discussion
    Last Post: 03-29-2010, 09:03 PM
  5. RWD conversion
    By flash527 in forum General Tech Discussion
    Last Post: 08-14-2009, 10:01 AM
