I was thinking of converting to HID Lights. Are there any things that I need to be concerned about? Flickering or any other Errors for the Computer?
get ddm 35w 6000k with the relay harnesses
I've had HID's for the last 3 years. They really don't help night time vision at all when installed in the 97-03 housings. I only put them in for appearance. After a 4 hour drive in the dark this last weekend, I decided that I will be upgrading to retrofits, as many before me have recommended.
If your heart is still set on plain old HID's, I'd suggest getting 9007 harness addapters from ebay. If you have to splice in a resistor like I did, this makes for a nice plug-n-play option for easy reversal.
2x 9007 HID Conversion Kit Error Free Load Resistors Wiring Harness Adapter ,4C | eBay
or
2 PCS Wiring Harness Connector 9004 9007 HB1 FB5 LED Light Bulb Extension Socket | eBay
good luck
get 35watt vvme 9007 single beam kit for low beams or get the bi xenon for his and lows.
i have vvme 35watt slim ballast bi xenon 8k for my headlights and vvme 35watt 8k single beam for my fogs. i've had them for about year and have had no problem what so ever.
