Thread: led reverse bulbs
Results 1 to 20 of 31
  1. #1 led reverse bulbs
    antioch ill
    i need some leds reverse bulbs i know there is a few out there that need these as well but is ebay my best bet to get them from?
    Autoillumination.com
    Don't cheap out on bulbs. EBay ones are ****.
  3. #3 Re: led reverse bulbs
    antioch ill
    yeah i figured they didnt have resistors built in
  4. #4 Re: led reverse bulbs
    antioch ill
    are blue reverse lights illegal?
  5. #5 Re: led reverse bulbs
    antioch ill
  6. #6 Re: led reverse bulbs
    Brightening up your day. Koniig's Avatar
    Jun 2010
    Illinois.
    Quote Originally Posted by Matt Palm View Post
    Technically, yes.
    Unless you're driving in reverse an entire night around town, you should be fine.
    My advice, do yourself a favor and get white.
  7. #7 Re: led reverse bulbs
    antioch ill
    i will and they are 30 bucks
  8. #8 Re: led reverse bulbs
    get an LED flasher. the load isn't high enough and you're gonna have hyperflash.
  9. #9 Re: led reverse bulbs
    antioch ill
    ok im lost please explain
    Blinker rate is based on the bulbs resistance. You need a new flasher module to run led lights correctly. That site sells flashers too. It plugs right in, easy as pie.
  11. #11 Re: led reverse bulbs
    antioch ill
    ok ill check it out any thing special i gotta look for in the flasher or does it fit all bulbs
    The flasher module is a little relay box under the dash. Then the bulbs plug in like normal.
  13. #13 Re: led reverse bulbs
    antioch ill
    hmmm i cant find them on there
  14. #14 Re: led reverse bulbs
    antioch ill
  15. #15 Re: led reverse bulbs
    antioch ill
    wait i didnt think i need a new module if im using them as reverse lights they arent going to be flashing at all
    You don't. But spend some moneys and replace all the bulbs. Do it.
  17. #17 Re: led reverse bulbs
    antioch ill
    i have led tails already and i have the stealth turn signals im gonna do all the leds inside soon
  18. #18 Re: led reverse bulbs
    antioch ill
    can i get any 3156 bulb and have it work fine or is there a special one that works best? so many options
  19. #19 Re: led reverse bulbs
    the thing that's gonna get you in trouble are some bulbs not fitting nicely through the holes in the tail lights.
    otherwise so long as it has the 3156 plug it'll work.
  20. #20 Re: led reverse bulbs
    GTP Level Member
    springfield IL
    I have some cree reverse lights installed... Go with them!! You wont me disappointed! And my rear windows are %5 tint. Can see just fine
  1. HIR bulbs?
    By DDPeppa in forum Visual/Body Modifications
    Last Post: 12-13-2010, 09:37 PM
  2. reverse
    By gotboost3 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-07-2009, 11:23 AM
  3. Dic Bulbs
    By J_Ferguson in forum General Tech Discussion
    Last Post: 10-21-2008, 06:07 PM
  4. fog bulbs
    By Toasty in forum General Tech Discussion
    Last Post: 03-26-2008, 10:23 PM
