Thread: HID High beam trigge
Results 1 to 10 of 10
  1. #1 HID High beam trigge
    GT Level Member BrendanMurphy's Avatar
    Jan 2012
    Keswick, Ontario
    I just installed 5k VVME hids into my headlights. I have the relay they are low beam only. To enable them i have to turn on my high beams then turn them off and than they come on. The high beam symbol is lightly illuminated when high beams are off aswell. Any insight as to why i need to use the high beams to toggle the relay?
  2. #2 Re: HID High beam trigge
    GTX Level Member Doug 97 gtp's Avatar
    Sep 2011
    palm harbor florida
    i know when you have single beam hids that the high beam light will always be on no matter what. and do you use your foglights when you have your headlights on?
    1997 GTP . repainted in jet black with blue pearl. rebuilt motor
    with vs cam ported heads and blower.
  3. #3 Re: HID High beam trigge
    Jan 2012
    Keswick, Ontario
    Quote Originally Posted by Doug 97 gtp View Post
    Yea i do, i have hid's for my fogs aswell but i haven't put them in yet.
  4. #4 Re: HID High beam trigge
    Sep 2011
    palm harbor florida
    ya if you have low beam hid's only the light will always be on. i have 8k 35watt in my fogs and i have the bi xenon in my headlights and when my fogs are on the high beam light shows up a little bit
  5. #5 Re: HID High beam trigge
    Jan 2012
    Keswick, Ontario
    Okay but why do i have to enable high beams for my low beams to turn on than turn them off for my fogs to come on.
  6. #6 Re: HID High beam trigge
    antioch ill
    couldnt you take out the high beam bulbs if you dont use them
    Dec 2010
    DMV
    I have the same exact hid kit from vvme and my high beam light isn't illuminated. You have to switch the pins in the harness. Doing so will make the high beam light to away.
  8. #8 Re: HID High beam trigge
    Jan 2012
    Keswick, Ontario
    Quote Originally Posted by Matt Palm View Post
    It's a Low beam only kit. So i trigger the high beam switch, the lights come on and then disable so my fogs will come on and they stay on.
  9. #9 Re: HID High beam trigge
    Sep 2011
    palm harbor florida
    What are you talking about there is only one bulb for high and low beams
  10. #10 Re: HID High beam trigge
    Sep 2011
    palm harbor florida
    Quote Originally Posted by BrendanMurphy View Post
    blue magic is right i had to switch 2 pins around in the connector in the relay harness to get mine to work. you can see what pins to move around in the ultimate hid thread.
  1. high beam indicator
    By BoostnBlackGTP in forum Visual/Body Modifications
    Last Post: 01-28-2011, 05:56 PM
  2. Need High Beam, Low Beam, Fog wiring help...
    By TuKoolGTP in forum General Tech Discussion
    Last Post: 12-29-2009, 12:57 PM
  3. New HIDs installed and High Beam/Low Beam issue CORRECTED!!! Woot!
    By GeddyLee in forum General Tech Discussion
    Last Post: 01-29-2009, 07:26 PM
  4. Hid with a high beam
    By crywolf in forum Visual/Body Modifications
    Last Post: 01-27-2009, 07:13 PM
  5. 04+ DRL and High/Low beam wiring
    By ponyfool in forum Visual/Body Modifications
    Last Post: 12-01-2008, 02:31 PM
