Thread: Headlight Housing
Results 1 to 9 of 9
  1. #1 Headlight Housing
    Im looking for just the replacement housing, i just got new corners and now the rest looks bad, ive looked everywhere i can think of..any help will appreciated.
    SMGPFC Member #10
  2. #2 Re: Headlight Housing
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    New Pair Set Headlight Headlamp Lens Assembly SAE DOT 97-03 Pontiac Grand Prix | eBay i got those they are factory looking has a little cheaper bracket i used my stock one and bolted the jug to it and installed the side marker looks good
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  3. #3 Re: Headlight Housing
    GTP Level Member
    Oct 2011
    Raleigh, NC
    Quote Originally Posted by 00grandprixgtp View Post
    How do the side markers look on these ? Do you think the assy will hold up on my daily driver ?
    1997 Red GTP 182000 miles stock
  4. #4 Re: Headlight Housing
    I might have a set i'll have to look in the garage.
  5. #5 Re: Headlight Housing
    im just looking for the headlight itself, not the bracket or the side light
    SMGPFC Member #10
  6. #6 Re: Headlight Housing
    Ok I'll look tom
  7. #7 Re: Headlight Housing
    Aug 2012
    Valley of the Sun, AZ
    Mine started looking a bit yellow, luckily I found some nice ones at my local pick-n-pull.....if you want my old ones and try a lens restore kit on them lmk.......$20 including shipping and you can have'em
  8. #8 Re: Headlight Housing
    Apr 2009
    Elkhart
    The lights look factory side included but the holders are cheap so u have to use ur old one
  9. #9 Re: Headlight Housing
    GTP Level Member
    Oct 2011
    Raleigh, NC
    Thanks
  1. Black headlight housing on white grand prix
    By GTLGDP in forum Visual/Body Modifications
    Last Post: 05-06-2012, 08:32 PM
  2. Two Morimoto projectors one cup...uh...I mean headlight...headlight
    By RedDawnGXP in forum Visual/Body Modifications
    Last Post: 03-23-2011, 05:07 PM
  3. headlight lens and housing
    By TDCRacing in forum Shops and Community Heroes
    Last Post: 08-30-2008, 01:14 PM
