Thread: Popeye HID
Results 1 to 7 of 7
  1. #1 Popeye HID
    GXP Level Member offroadfury6's Avatar
    Aug 2008
    Fayetteville, NC
    Yeah So i've been running my DDM's for about 6 months or so now, no issues...just pulled up and noticed on the garage door that only 1 was on...I fiddled with the wires alittle to see if there was a short, nothing....I'm just guessing the bulb is blown. I had no warning signs like flickering or flashing etc...just bam, OUT! ... I am running a wiring harness also sooo...suggestions anyone? is there an easy tell-tell way to see if the ballast is gone vs the bulb?
    thanks...
    2011 Honda Civic EX-L - Leather/Sunroof/LOADED!
    2009 Saturn Aura XE - I got shift paddles!!!
    '98 Olds Cutlass - Good, Dependable
    '06 GP GT S/C - Traded it in
  2. #2 Re: Popeye HID
    GTP Level Member
    Pittsburgh
    do you have the relay harness. the GP Wire harness is not the best to the HID's
    Did you try turning them off and then on again?
    2003 SSEi,
  3. #3 Re: Popeye HID
    West Side Michigan
    Take the bulb that is working and connect it to the ballast that had the blown bulb nd vice versa. If the side that wasn't working starts working, then it's the bulb. If it still isn't working, then it's probably the ballast. Good luck! Let us know what happens
  4. #4 Re: Popeye HID
    Aug 2008
    Fayetteville, NC
    Quote Originally Posted by 2003 SSEi View Post
    Yes, I stated above that I did have a wiring harness installed...relay/whatever, same thing...
    Quote Originally Posted by nawarkk View Post
    ahhhhh...I was trying to avoid this because I'm lazy and don't fell like ****ing with it after the past 4 weeks, putting in 2 wheel bearings, doing an oil change, getting tire pressure back right, new waterpump and replacing the plastic coolant elbows...alittle sick of turning wrenches on it ATM...
  5. #5 Re: Popeye HID
    The LED guy.... csssaint12's Avatar
    Nov 2009
    Duluth, Minnesota, United States
    Could use a 12V meter and see if the ballast has a closed circuit
  6. #6 Re: Popeye HID
    Jul 2008
    Tampa, FL
    i did that like 50x, and then i finally broke down and bought a frickin relay harness...stupid gm wiring...good luck with your ballast though...
  7. #7 Re: Popeye HID
    Aug 2008
    Fayetteville, NC
    fixed i guess. I cut it off and on...bam back to working...hmm???
