Thread: Installing Roof Rails
Results 1 to 10 of 10
DanPrixGTP Installing Roof Rails 05-27-2012, 02:35 PM
rvnwlf Re: Installing Roof Rails 05-27-2012, 04:57 PM
231FUN Re: Installing Roof Rails 05-27-2012, 05:12 PM
Fivefingerdeathpunch Re: Installing Roof Rails 05-27-2012, 05:13 PM
Mad Monkey Re: Installing Roof Rails 05-27-2012, 05:16 PM
DanPrixGTP Re: Installing Roof Rails 05-27-2012, 05:40 PM
Mad Monkey Re: Installing Roof Rails 05-27-2012, 05:43 PM
DanPrixGTP Re: Installing Roof Rails 05-27-2012, 05:59 PM
Mad Monkey Re: Installing Roof Rails 05-27-2012, 06:02 PM
Ricky21 Re: Installing Roof Rails 05-27-2012, 06:06 PM
  1. #1 Installing Roof Rails
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    Finally, i am a part of the cool group because i just bought myself some black roof rails off a member here. The rails will be here thursday, im excited. Anyway, how do you install them? Im sure i need to remove this...
    But how?
    Im guessing its glued in, so whats the easiest method to removing this stock strip and loosening up the glue and what not?
    AND...
    What do you all use to hold the roof rails down? 3M Tape, some kind of glue?
  2. #2 Re: Installing Roof Rails
    Aug 2011
    Orland, Me
    Good question. I have a set of roof rails that are starting to peal up. From what I can see it looks like some kind of a caulk/glue was used to hold them down. I'm thinking about cleaning that all out and using the 3M molding tape myself.
  3. #3 Re: Installing Roof Rails
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    You don't remove anything, just use the 3M double sided tape and stick them on there.
  4. #4 Re: Installing Roof Rails
    Quote Originally Posted by 231FUN View Post
    You have to remove the stock trim.
    Have you ever seen the bottom of a roof rail?
    Its not flat.
  5. #5 Re: Installing Roof Rails
    London Ont, Canada
    yeah, remove the stock trim "rail".. just pull it up and off, hot day makes it easier
    then us 3M tape to put it back down after cleaning out the channel!
  6. #6 Re: Installing Roof Rails
    Jun 2011
    Thanks monkey. What would I do without you?
  7. #7 Re: Installing Roof Rails
    London Ont, Canada
    I've pulled them before, its got that stupid foam adhesive crap, so have fun cleaning it up, lol
    goo gone, rags, and time
  8. #8 Re: Installing Roof Rails
    Jun 2011
    Is it tough to just pull out the stock rail?
  9. #9 Re: Installing Roof Rails
    London Ont, Canada
    not really, once you get under it, it pulls easy,
    you can even do the fishing line trick, treat them like a badge, held on EXACTLY the same
  10. #10 Re: Installing Roof Rails
    Minnesota
    I dont think you can put them on your car.. So you can just send them to me and il get rid of em for ya
    Open cone, SSAC headers, cat delete, 8.5 MSD wires, 3.4 zzp mps, 180*, 104's, ported blower, DHP canned tune, 19" XXR 962s, DNA springs.
