Thread: LED turn signal. Hyper flash fix - Which one?
Results 1 to 18 of 18
  1. #1 LED turn signal. Hyper flash fix - Which one?
    GTX Level Member Freebeer187's Avatar
    Bartlett, IL
    Im putting in switchback led running lights (leaving corners amber atm). Which solution should I use for fixing the hyperflash?
    3156 3056 Hyper Flash Fix No Error Wiring Adapters For LED Turn Signal Lights | eBay
    or
    Follow this tutorial and purchase one of these Tridon EP28 Flasher relays?
    How To: E-Brake Pwn
    2001 GTP. D/S Rotors * Custom Intake * DHP PCM *
    Looking For - 3" in DP with Cat. PM me if selling
  2. #2 Re: LED turn signal. Hyper flash fix - Which one?
    Dec 2008
    Lawndale, CA
    Either the write up or the flasher is the best option.
  3. #3 Re: LED turn signal. Hyper flash fix - Which one?
    Jul 2010
    Coquitlam,BC,Canada
    Change the flasher.
    The modules and adapters just simulate the load of a regular bulb, so you don't gain the electrical advantage of going LED, other than the looks.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  4. #4 Re: LED turn signal. Hyper flash fix - Which one?
  5. #5 Re: LED turn signal. Hyper flash fix - Which one?
    Feb 2010
    TN
    I changed the flasher, its fast and easy
  6. #6 Re: LED turn signal. Hyper flash fix - Which one?
    Quincy, Mass
    go autozone or similar parts store and get the flasher that has 3 prongs on the bottom instead of 2, i think its ep29 but im not positive, cut off the middle prong and install. all done no more hyperflash. i have switchbacks too.
    No more GP 04 Impala SS Indy:
  7. #7 Re: LED turn signal. Hyper flash fix - Which one?
    Pretty sure you got the number right.
  8. #8 Re: LED turn signal. Hyper flash fix - Which one?
    why cant you get one to plug right in and work correctly? you really have to trim a tab off the EP29?
    http://www.superbrightleds.com/cgi-b...2Fflashers.htm
  9. #9 Re: LED turn signal. Hyper flash fix - Which one?
    Jul 2010
    Coquitlam,BC,Canada
    EP28 is a direct plug in:
    EP29 has an extra terminal:
    If you have to buy a new flasher, why not buy the right one, EP28.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  10. #10 Re: LED turn signal. Hyper flash fix - Which one?
  11. #11 Re: LED turn signal. Hyper flash fix - Which one?
    Feb 2010
    TN
    Agreed EP28 is what I used
  12. #12 Re: LED turn signal. Hyper flash fix - Which one?
    I found a writeup for the 29 and no info on 28. You guys suck, but I have skill for getting that tab off.
  13. #13 Re: LED turn signal. Hyper flash fix - Which one?
    Jul 2010
    Coquitlam,BC,Canada
    Check post #1. Kinda hard not to find. LOL
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
    Quincy, Mass
    I had ordered one from autolumination and it was an ep29 w the prong trimmed off. Then I broke it so I went to advance auto and got an ep29 and trimmed the prong and it worked like its supposed to.
  15. #15 Re: LED turn signal. Hyper flash fix - Which one?
    Quote Originally Posted by Bronco Boy View Post
    Wasn't on this forum or maybe post #1 didn't exist when I did it. Kinda hard not to get a wise answer from me when you word it like that Bubba Gump ... LOL
  16. #16 Re: LED turn signal. Hyper flash fix - Which one?
    Feb 2010
    TN
    Oh Bill you know youlikr the challangeofmodding things LOL
  17. #17 Re: LED turn signal. Hyper flash fix - Which one?
    GT Level Member 1996pontiac's Avatar
    Livonia, Michigan, United States
    Where would the ep28 relay go? Can't find it
    1999 Red Pontiac Grand Prix GTP/120xxx miles
    Mods- Intake
  18. #18 Re: LED turn signal. Hyper flash fix - Which one?
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by 1996pontiac View Post
    Open left door, remove dash side cover.....
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  1. Turn signal
    By penguinknot in forum General Tech Discussion
    Last Post: 09-11-2011, 04:46 PM
  2. turn signal help
    By sUpErClEaNbLaCkMaChInE in forum Audio, Security & Visual Electronics
    Last Post: 02-17-2011, 08:09 PM
  3. 94 Grand Prix speedo moves with signal flash
    By AMXTRA in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-21-2010, 12:36 AM
  4. 04 turn signal?
    By shawns14 in forum General Tech Discussion
    Last Post: 11-28-2009, 10:57 PM
