Thread: will sedan seats fit coupe?
Results 1 to 15 of 15
  1. #1 will sedan seats fit coupe?
    GT Level Member crazybrownklick's Avatar
    May 2011
    El paso tx
    Chats
    found great deal on sedan seat will they fit the coupe?
  2. #2 Re: will sedan seats fit coupe?
    Grocery Getter x2 goldgp's Avatar
    redneck tennessee
    Chats
    272
    They will fit, but they will not fold back.So it will be hard to access the back seats.
    1998 GTP Mods: Getrag 5 speed ,balanced bottom end,ARP hardware,L32 rods,Federal pistons .20 over,XP Cammed,Double roller,130# springs,and 3.4 Gen V,SSC springs,GMPP sways, C5 calipers,12 inch brakes.2000 Grand Prix SE 3.8 Mods: GT dual exaust,plog,downpipe,Transgo Shift kit,1.9 yella terra rr,strut braces,gmpp kit.Both noob tuned with HP Tuner
  3. #3 Re: will sedan seats fit coupe?
    May 2011
    El paso tx
    Chats
    what about the rear us there anything different with it?
  4. #4 Re: will sedan seats fit coupe?
    Grand Rapids, MI
    Chats
    74545
    they're the same. only difference is like Kenny said, the passenger seats folds down on the coupes. and the coupes have those fancy seat belt things on them.
  5. #5 Re: will sedan seats fit coupe?
    Donating User Odi's Avatar
    Chicago South Suburbs
    Chats
    43199
    rears seats iirc are wider in the 4 doors.
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    Chats
    2347
    No, they are not wider. The seats are exactly the same.
    Sent from my DROID RAZR using Tapatalk 2
    For all your 3800 needs:
  7. #7 Re: will sedan seats fit coupe?
    May 2011
    El paso tx
    Chats
    thanks install them they look great
  8. #8 Re: will sedan seats fit coupe?
    Texas
    Chats
    You should go baller and install two front seats in the rear passenger area. Looks really clean with a center console in the middle.
    85 Corvette
    01 TA
    03 Z06
  9. #9 Re: will sedan seats fit coupe?
    GT Level Member djrepoman's Avatar
    columbus ohio (polaris)
    Chats
    12
    anyone ever come up with a way to make sedan seats flip fwd to work in a coupe?
    2000 GT ,E85 powered, and still slow
    98 GTP Stock
  10. #10 Re: will sedan seats fit coupe?
    Dec 2014
    Upstate, NY
    Chats
    What's the reason for replacing the seats? Could you just replace the cover on the passenger seat? you might need to make the hole for the flip forward lever, but then you'd retain the function.
    DISCLAIMER: I propose possible ideas that probably require way more time and effort than reasonable. Ask Bill.
  11. #11 Re: will sedan seats fit coupe?
    Donating Users NotEnoughGPs's Avatar
    Aug 2013
    Pittsburgh, PA
    Chats
    178
    I recently purchased 2 tone seats (graphite and silver) out of a '01 Special Edition sedan from Washington, DC that are in A-1 shape. Thanks jayroca.
    My intention is to install in my 2-door GP.
    I have removed the leather covers with minimal effort, and will be shortly removing the graphite colored leather covers from the seats in my coupe.
    Getting the covers back on the seat frame requires more effort. It is more difficult than it seems.
    I will let you know when this is finished.
    Also, about the rear seats, the ones from a sedan are the same as a coupe. They install in the same manner as the ones in a coupe. Not sure what the pictures from posts from years past were referring to about not being as wide or as tall in the back.
    And I can tell you, I do not see anyway that the front seats from a sedan could be modified to fold forward to allow passengers to get in the back seat (like the ones in a coupe)
  12. #12 Re: will sedan seats fit coupe?
    GT Level Member MyLittlePony's Avatar
    Mar 2015
    Franklin, TN
    Chats
    2173
    Are the rails on a sedan different than coupes? I swear my mom's sedan front seats go further back than my coupe seats. Maybe the motors are just that bad.
  13. #13 Re: will sedan seats fit coupe?
    SE Level Member Blacknight02GT's Avatar
    Feb 2009
    Buffalo,NY
    Chats
    Quote Originally Posted by djrepoman View Post
    Hey I know this thread is 6 years old but I’ve recently purchased some 02 40th anniversary seats off a sedan with 56k on it that are minty. I’m looking to install in my coupe. The rears were easy to put in but I’m thinking there has got to be a way to modify at least the passenger side seat so it can flip forward. Anyone know what the mechanism inside looks like the releases the seat to flip forward?
    2002 Grand Prix GT (K&N + Ram Air = BEAST)
  14. #14 Re: will sedan seats fit coupe?
    Mar 2018
    NY
    Chats
    You can swap in seats from an 04+. The passenger seat folds flat on those so you at least still have rear seat access. Its a fairly simple swap. IIRC The fronts bolt right in you just have to do some modifications to the harness for the power driver's side. The rear seat back bolts in, the base you just have to cut the holes where the latches go a little. There were a couple coupes around back in the day with this setup.
  15. #15 Re: will sedan seats fit coupe?
    Mar 2018
    NY
    Chats
    hehe I didn't realize how old this thread was.
    Quote Originally Posted by Blacknight02GT View Post
    To answer your question the easiest way would probably be to swap the seat coverings over your old seats
  1. Old Thread
    By SpeedGrid in forum General Grand Prix Discussion
    Last Post: 11-21-2021, 10:56 AM
  2. coupe vs sedan springs
    By sweetgtx98 in forum General Tech Discussion
    Last Post: 09-27-2011, 05:06 PM
  3. ? stock: coupe or sedan
    By Ryansgtp in forum Track Sessions and Kills
    Last Post: 11-10-2010, 08:34 PM
  4. 99 accord V6 coupe vs. 00 gp gt sedan
    By JB Miller in forum Track Sessions and Kills
    Last Post: 06-09-2009, 09:49 PM
  5. sedan or coupe?
    By mexico in forum Off Topic Discussion
    Last Post: 05-30-2008, 07:28 AM
