Thread: Thinking about retro fitting, looking for opinions
Results 1 to 20 of 35
  1. #1 Thinking about retro fitting, looking for opinions
    SE Level Member hockey101's Avatar
    Detroit, Michigan
    So I'm starting to think I want to retro fit my headlights. I figure now would be the time for me to do it since spring break is coming up and I'll have a 10 day break form school.
    I was thinking of going with the Bi-xenon morimoto mini H1 kit from the retro fit source with 35w 5000k hid's. However i'm not quite set on which shrouds (graphite or gattling) I want or if I want black or chrome headlight housings.
    As for shrouds i think the mini graphite would be cool but I can't seem to find a pic of them while the lights are on. I was also thinking about the idea of getting angel eyes with them but I think a single angel eye in each headlight would look weird.
    Here is a pic of the front of my car. Photo shopping black housings in and/or photos of white cars with black housings is encouraged.
    [IMG][/IMG]
  2. #2 Re: Thinking about retro fitting, looking for opinions
    Apr 2009
    Maine
  3. #3 Re: Thinking about retro fitting, looking for opinions
    Detroit, Michigan
    Thanks, J.
    Anybody have thoughts on the shrouds or angel eyes?
    I also want 5000k hids for my fogs and i'm wondering if i should get projectors for those as well. will i blind people if i don't get projectors for the fogs?
  4. #4 Re: Thinking about retro fitting, looking for opinions
    run no shrouds like a boss. make the projectors blend in when they are off.
  5. #5 Re: Thinking about retro fitting, looking for opinions
    If you use the shrouds, you have to use the mini gatling gun shrouds or else they wont fit at all.
    Also they have to be cut to fit inside the headlight.
  6. #6 Re: Thinking about retro fitting, looking for opinions
    Detroit, Michigan
    Ok, so right about now for headlights i'm thinking stock housings (chrome) with mini gattling shrouds.
    I should be fine putting hid's in the stock fogs right?
  7. #7 Re: Thinking about retro fitting, looking for opinions
    Detroit, Michigan
    Ordered my stuff today. this is what i got:
    From Theretrofitsource.com
    - morimoto mini 4.1 H1 projectors
    - Bi-Xenon 9007 harness
    From DDM Tuning
    - 35W 5000k H1 HID Kit
    - 35W 5000k 880 HID kit
    - Wiring harness
    What should i use to reseal the housings? just clear silicone?
  8. #8 Re: Thinking about retro fitting, looking for opinions
    yeah a clear window silicone
  9. #9 Re: Thinking about retro fitting, looking for opinions
    Detroit, Michigan
    thanks. I plan on following xogiox's write up from over on club gp
    http://www.clubgp.com/newforum/tm.as...mode=1&smode=1
    if you guys did anything different that may have been easier i would appreciate the tips.
    If i opt to go the oven route to help remove the lenses how hot and how long should i leave them in there?
    the reason why im asking is because i've seen some people say 150* for 8 min and others say 230* or even 250* for 8 min.
  10. #10 Re: Thinking about retro fitting, looking for opinions
    SE Level Member Dzebold's Avatar
    Apr 2011
    Darien, Illinois, United States
    I got mine off with 225 for about 20 minutes, but I was checking about every 5 minutes.
  11. #11 Re: Thinking about retro fitting, looking for opinions
    Ontario
    Frankly I think the car looks better with the stockers. Good luck with your retrofit though!
  12. #12 Re: Thinking about retro fitting, looking for opinions
    Depends really. I'd say 210ish for about 10-12 min, then longer if needed.
  13. #13 Re: Thinking about retro fitting, looking for opinions
    MA
    i did 245* for 12mins. worked nicely.
    SMGPFC Member #9
  14. #14 Re: Thinking about retro fitting, looking for opinions
    Detroit, Michigan
    Thanks guys. Did that make the house smell at all? And where did you guys end up putting your ballasts? i ended up ordering mounting brackets with my kit. i figured $4 might save me time and hassle, and if i don't use them oh well.
    Quincy, Mass
    Make sure you finish aiming them and they are where you want them before you seal them back up. Once the windshield caulk is on they aren't coming apart again
    No more GP 04 Impala SS Indy:
  16. #16 Re: Thinking about retro fitting, looking for opinions
    Detroit, Michigan
    does anybody know of any other write ups for retro fitting 97-03 headlights?
    And how should i secure the projector? epoxy?
  17. #17 Re: Thinking about retro fitting, looking for opinions
    Detroit, Michigan
    ttt
  18. #18 Re: Thinking about retro fitting, looking for opinions
    Apr 2011
    Backinblack had some real good posts alongwith cleangtp, although clean is no longer on here so his pics are gone. Search the thread "let there be LIGHT! Morimoto mini retro fit". It should help. That's what I'm using for my basis.
  19. #19 Re: Thinking about retro fitting, looking for opinions
    Nov 2011
    NY
    Cleans Official Retrofit Thread. Pictures of Work.
    Post Retrofit Pics
    Those are two for ya'... other than that, you'll have to search and search, Google should be your friend! There are literally hundreds of write ups, you've just got to be patient and read as much as possible until you are comfortable.
    Good Luck!
  20. #20 Re: Thinking about retro fitting, looking for opinions
    Detroit, Michigan
    thanks guys
  1. anyone make 04+ retro?
    By tayl5645 in forum Visual/Body Modifications
    Last Post: 03-17-2011, 08:40 PM
  2. retro fit
    Last Post: 02-16-2011, 11:12 PM
  3. anyone ever try these for retro fit?
    Last Post: 02-03-2011, 10:32 PM
  4. Thinking of going cammed... Need opinions
    By crbquist in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-08-2010, 08:02 AM
