Thread: started changing the interor lighting to leds, and cleaned up the trunk a bit
Results 1 to 20 of 22
  1. #1 started changing the interor lighting to leds, and cleaned up the trunk a bit
    GT Level Member nicks98gtp's Avatar
    michigan
    well i finally started the switch to leds on my interior, so far ive got the gauges done, one lock switch, and the fog light switch. gotta order some more leds now lol. This is deffinately much brighter than stock, and i love it so far.
    Heres a quick shot of the trunk after i tucked all the wiring
    Heres the lock switch i got done
    Fog light switch
    and the gauges
    98 Gtp, ported s/c, fully rebuilt motor .20 oversized pistons, rebuilt trans, zzp pcm,more mods to come
  2. #2 Re: started changing the interor lighting to leds, and cleaned up the trunk a bit
    Yoga city
    how did you do the gauges?\
  3. #3 Re: started changing the interor lighting to leds, and cleaned up the trunk a bit
    michigan
    ordered some blue leds off ebay (search blue led 194) which is how i found them, and they slide right in the twist lock connectors that hold the old bulbs. as far as the gauge face itself, you have to pull the cluster out, pull the front cover off that goes over the inlay/needles. Pull the needs off carefully, and pull the gauge face off. It is just held on with glue and it takes a little work to get it off. after its removed, get some goo gone and remove the glue on the back. after the glue was gone, i took some 320 grit sandpaper and went over the entire surface of it (minus warning indicators) until you could hold it up to the light and not see red through it. after all the red is gone, reassemble everything and you should be good to go.
  4. #4 Re: started changing the interor lighting to leds, and cleaned up the trunk a bit
    Yoga city
    i did that on my shifter selecter by the actually shifter, when there of does it look clear to you?
  5. #5 Re: started changing the interor lighting to leds, and cleaned up the trunk a bit
    Grand Pricks cameron92's Avatar
    May 2011
    Orangeville, Ontario, Canada
    How did you do the switches, are they just plug and play LED's aswell?
  6. #6 Re: started changing the interor lighting to leds, and cleaned up the trunk a bit
    Yoga city
    i know this, there not solder will be required for any of the sswitches
  7. #7 Re: started changing the interor lighting to leds, and cleaned up the trunk a bit
    May 2011
  8. #8 Re: started changing the interor lighting to leds, and cleaned up the trunk a bit
    GTX Level Member Doug 97 gtp's Avatar
    Sep 2011
    palm harbor florida
    Quote Originally Posted by Jteske88 View Post
    was it hard to do that to the shift selector
  9. #9 Re: started changing the interor lighting to leds, and cleaned up the trunk a bit
    michigan
    jteske: im not sure what your asking, but my gauges are pretty clear and bright if thats what your asking.
    c
    ameron: no the switches were a little more involved, i pulled the switches apart and disassembled them. On the bottom of each led youll see two posts that theyre soldered to. I plugged the switches in to the harness when they were still torn apart and used a voltmeter to see which pin supplied the voltage when the lights were switched on. Next i desoldered the old leds, set up my new resistor, and led setup, and glued them in place. after i found where they would fit and everything would go back together i ran the power side of the led to the posative pin on the switch connector that you checked power for earlier, and the neg. side of the led to the other spot on the switch. I will be doing the other switches tommorow if radioshack got more leds in, and ill take some pictures to better describe it
  10. #10 Re: started changing the interor lighting to leds, and cleaned up the trunk a bit
    michigan
    and doug, it should be a plug and play twist lock connector on the shift selector, so you should be able to use one of the same bulbs the cluster used if you had some left over ( i think theyre the same size bulb but not posative since i havent done the shift selector yet)
  11. #11 Re: started changing the interor lighting to leds, and cleaned up the trunk a bit
    Sep 2011
    palm harbor florida
    ok cool and i just wanted to show you what blud led interior lights look like i have them in my car and i like them alot i think i pent a total of 15 bukcs for all of them. i need to paint my jams really bad i hate that green blah
  12. #12 Re: started changing the interor lighting to leds, and cleaned up the trunk a bit
    michigan
    just went and threw in my extra bulb in my shift socket its the 194 bulb, just plug n play
  13. #13 Re: started changing the interor lighting to leds, and cleaned up the trunk a bit
    Sep 2011
    palm harbor florida
    alright cool ill have to get some more leds then
  14. #14 Re: started changing the interor lighting to leds, and cleaned up the trunk a bit
    michigan
    if your gonne get more, id a brighter one for the gevr selector, the ones i have lit it up, but the (p, 1) arent lit which doesnt bother me considering i had the bulb anyways, and it was burnt out before so its still better than it was lol. but if your gonna order them, might vs well get some brighter ones if you want all the gears to show up.
  15. #15 Re: started changing the interor lighting to leds, and cleaned up the trunk a bit
    Sep 2011
    palm harbor florida
    i might get some from diode dynamics maybe these will work 194 2-5050 SMD
    h
    ow many bulbs does it take
  16. #16 Re: started changing the interor lighting to leds, and cleaned up the trunk a bit
    michigan
    looks like theyll work to me, and there is just one. not sure if theres more on the 97, i wouldnt think so but mine had one right in the middle on the underside
  17. #17 Re: started changing the interor lighting to leds, and cleaned up the trunk a bit
    Sep 2011
    palm harbor florida
    ok i might try the 4 led bulb
  18. #18 Re: started changing the interor lighting to leds, and cleaned up the trunk a bit
    michigan
    that should be more than enough, you may be able to do some sanding on the underside of the shift indicator panel also so the light will come through better, it was dark, and really cold though so i didnt take to close of a look lol
  19. #19 Re: started changing the interor lighting to leds, and cleaned up the trunk a bit
    Sep 2011
    palm harbor florida
    Ok well ill probably rip mine apart tomorrow after school.
  20. #20 Re: started changing the interor lighting to leds, and cleaned up the trunk a bit
    michigan
    let me know how it goes, hopefully radioshack has some moer led so i can finish my switches, and get a more detailed write up
  1. Trunk Lighting????
    By nikkigpgt00 in forum Audio, Security & Visual Electronics
    Last Post: 01-19-2013, 08:58 PM
  2. Cleaned my TB and MAF...
    By armyrebel03 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-08-2011, 03:24 PM
  3. all cleaned up!
    By kuntzie in forum Visual/Body Modifications
    Last Post: 05-22-2010, 01:03 PM
  4. Cleaned up (on going)
    By stlmo_gtp in forum Visual/Body Modifications
    Last Post: 10-29-2008, 04:20 PM
  5. Changing LEDs in your angel eyes [*]
    By Preotic in forum How To Write-Ups/Tech Tips
    Last Post: 04-11-2008, 11:05 PM
