Thread: roll cage/ gutted interior
Page 2 of 6 FirstFirst 1234 ... LastLast
Results 21 to 40 of 106
  1. #21 Re: roll cage/ gutted interior
    Donating Users Taz Magister's Avatar
    Dec 2010
    Ohio
    So half a second faster worth it
  2. #22 Re: roll cage/ gutted interior
    Omaha, NE
    Full nascar style cage or gtfo.
  3. #23 Re: roll cage/ gutted interior
    Dec 2010
    Ohio
    Any idea how much an aluminum sub frame will cost me at a junk yard ?
  4. #24 Re: roll cage/ gutted interior
    SE Level Member Mater's Avatar
    Feb 2010
    my house
    car-part.com
    search engine cradle for any 04+ w-body
    in my area $500
    But why make it an SE?
    99 Grand Prix SE coupe:
    junk yard trans junk yard engine and junk yard turbo
    03 Silverado 2500HD ECSB: 6.0 4x4 01 Aurora:​ 4.0L vin number 2
  5. #25 Re: roll cage/ gutted interior
    SE Level Member kygtp's Avatar
    Oct 2008
    Cincy
    Quote Originally Posted by FoSHO99 View Post
    This has most of this stuff already covered...
    ClubGP Message Forum troubleshooting
    I think that may be taking it a little far. But it would be nice to see how it holds up over time. IMO, the sub frame is the one thing I would not want to modify, since that is the main support for the whole front end of the car, and taking the abuse of all the force that the motor puts on it as well. Looks nice though.
    Bunnell, FL
    From what I can see it looks ti be done.right. everything is. Centered and on support.braces.for the.most part. So it is fully functional to an extent. I would not have done the lateral bars based on what I can see here
    Kindle Fire: The Keyboard Sucks, So Please Forgive Mass Misspelling
    I'm a Sex Offender
  7. #27 Re: roll cage/ gutted interior
    Feb 2009
    flintnasty MI
    Its worth quite a bit to lose the weight... most all of the "fast" wbodies out there are lighter than my fiero.
  8. #28 Re: roll cage/ gutted interior
    Alum subframes are about $75 here.
  9. #29 Re: roll cage/ gutted interior
    PA
    I don't think you'll do it Taz. Just lock this thread. ;-)
    2001 GSE
  10. #30 Re: roll cage/ gutted interior
    I'm confused on something though.
    You added 100lbs or more of wiring to move your fusebox, now you wanna save weight. Odd thought process you have there.
  11. #31 Re: roll cage/ gutted interior
    Jan 1970
    Maquoketa, Iowa
    Another good example would be Ron Vogels' car, but threads of his weight reduction pics are hard to find.
    I have the interior gutted from the rear seats back, the problem I have is living on a gravel road, the dust just rolls in and it's going to be a pain to seal everything up. Also the 3rd brake light needs to be covered or everytime I hit the brakes at night it lights up everything. I can fit my slicks and all tools pretty easily for the track.
    I'd like to gut mine, get manual windows and use some sheet metal to dress it up so it doesn't look like complete crap in there.
  12. #32 Re: roll cage/ gutted interior
    Dec 2010
    Ohio
    I added maybe 6lbs of wiring and I ripe all the On star wiring out, and 500 seems like a lot for a subframe
  13. #33 Re: roll cage/ gutted interior
    Dec 2010
    Ohio
    Quote Originally Posted by Zef_66 View Post
    I think you said the same thing about my wire tuck
  14. #34 Re: roll cage/ gutted interior
    Quote Originally Posted by kygtp View Post
    I have gutted my interior some what and have gotten the car down to around 3000. I took out the rear seats, all the rear speakers, BUT put the rear cover back in place since it only weighs about a pound or so. Passanger seat is removed, AC delet, with everything that goes with it. Cruise control is gone. Alum sub frame up front. Rear Steel bumper support is removed, the front support has a pretty big peice cut off of it for my Frozen boost FMHE. Everything in the truck in gone that I could pull out as well.
    I still have all my panels in the car, since they do not weigh a whole lot, plus it makes the car look nicer with them in place. I still have speakers in the door, so I can listen to tunes when I do drive it on the street. I have a full dash still as well. I think that is all that I can remember off the top of my head.
    The only problem is, is I hope with my new build that I will dip into the low 11's, but that means I will have to put a cage in, and I will be back to where I was, with the added weight. But that is ONLY if I can get there..........
    Have you weighed it?
    Because I dont buy 400-500 lbs of weight reduction with a few interior pieces.
  15. #35 Re: roll cage/ gutted interior
    Oct 2008
    Cincy
    Yes I have and I dont buy it either.
    I realize now that in my first sentence that it comes across as just interior parts, but if you read on in my responce I list everything else that I have taken off the car that I can remember taking off. The last time that I weighed it at the track it was 3050 with me OUT of the car.
  16. #36 Re: roll cage/ gutted interior
    what's the weight difference from a steel to alum subframe? What's needed to make it fit? or does it just bolt up? I have mother natures weight reduction in my car and it's just getting lighter everyday.
  17. #37 Re: roll cage/ gutted interior
    Waukesha, WI
    just bolt n go,
    like 38lbs ish/
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  18. #38 Re: roll cage/ gutted interior
    Portland Oregon
    IIRC it's around 20 pounds
  19. #39 Re: roll cage/ gutted interior
    Dec 2010
    Ohio
    So ill gut the car and when I change the subframe ill build the trans and xpz build unless someone buys the car before I have the funds
  20. #40 Re: roll cage/ gutted interior
    Dec 2010
    Ohio
    comfy looking huh
  1. Windows roll down fine but roll up SLLLOOOOWWLLYYY
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2013, 07:21 PM
  2. My new beard cage.
    By JoshsGTP in forum Off Topic Discussion
    Last Post: 10-11-2011, 06:49 AM
  3. Gutted Turbo Hatchback Civic=RAPING
    By chevyy1212 in forum Track Sessions and Kills
    Last Post: 06-08-2011, 10:19 PM
  4. 1/4 Mile: Helmet? Roll Cage?
    By GrandPrixGTP1 in forum Off Topic Discussion
    Last Post: 01-10-2011, 12:42 PM
  5. Gutted Airbox pictures
    By IndeedSS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-14-2010, 05:44 AM
