Thread: Painted SC
Results 1 to 15 of 15
  1. #1 Painted SC
    SE Level Member vantage08's Avatar
    warminster
    Hey guys. Has anybody painted their supercharger and intake? Mine is sanded down because the valve gaskets were getting changed and apparently the intake was seeping. So, I decided to clean up this ugly corrosion. I have a GM multicolor gloss black that I have one coat on so far after being sanded down and cleaned. Anything suggestions/ how many coats did you use?
    Brent
    back on.
    What do youguys think?
    2005 Grand Prix- GTP-COMP.G-mods- K&N Intake, 180TSTAT,Liquid Metal Wheels, LED everything,605s, ZZP 3IN cat back.,Pacesetters,Inferno Hood+Air Dam, HPtune, HIDs.
  2. #2 Re: Painted SC
    the usual 2-3 coats should do it just fine. lots of people paint their blower with zero ill effects.
    moved to a more appropriate section, as well.
  3. #3 Re: Painted SC
    May 2011
    Kansas City
    looks good man
    Reptile Tune (SOLD)
  4. #4 Re: Painted SC
    Kansas
    I know a lot of people powdercoat the supercharger. Painted SC look good, but retain the heat even more.
  5. #5 Re: Painted SC
    warminster
    THanks!
  6. #6 Re: Painted SC
    Nov 2011
    NY
    just finished my SC a few days ago, the TB too.
    Here's a few pics... Just cleaned it real good (brake cleaner works well) and let it dry good too. Then mask off any openings, take your time here. When applying the paint, use HIGH HEAT ENGINE paint... (I used Dupli-Color Ceramic Engine Paint)... Go real slow, many light coats are better than one heavy and the Ceramic Paint is real THIN too so will run easy - a light touch is needed. It dries pretty fast, I did 3 light coats about 15 mins a part, then one heavier coat an hour or so later and all was done.
    Finished product with new pulley and all parts back on as well
  7. #7 Re: Painted SC
    you dont need high temp paint. the blower doesnt really exceed anything very high (literally 300* max, considering you can touch the blower without melting your hand off immediately after shutting the car off. it's hot, but not that hot.) and at that temperature it will just help the paint to bake on better.
  8. #8 Re: Painted SC
    Nov 2011
    NY
    I just figured the High Temp Paint would have better durability (Ceramic) than consideration for the heat, and price is same so just a choice is all... The paint is weirdly thin though, lol, almost like water...
  9. #9 Re: Painted SC
    Portland Oregon
    Nice. my blower on the Regal is all kinds of oxidised due to it being a New York car before I bought it. I'm likely going to look into a ported replacement at some point and paint it with something like wrinkle black.
  10. #10 Re: Painted SC
    warminster
    Looks good! I didn't take my time because the car was in a friends garage, not mine so I didn't want to hold up his time. I knew I could have done a better clean job used tar and wax removed on it( quick wipe down). It def has it's imperfections because of it but maybe another time and part.
  11. #11 Re: Painted SC
    Instead of sanding. I used Krylon wrinkle paint. Hid all the imperfections and was easy to work with.
    did it on the Gen V, IC, LIM. No one even noticed the IC in the engine bay after that.
  12. #12 Re: Painted SC
    Iowa
    Looks good man. Heres my engine bay...
  13. #13 Re: Painted SC
    warminster
    Nice!!
  14. #14 Re: Painted SC
    Portland Oregon
    Just did mine while it was off the car. Low gloss (nearly a flat, my camera flash just makes it look shiny) black engine paint. 3 coats is what I've got on there. Gonna put it on tomorrow when I get a blower gasket and elbows.
  15. #15 Re: Painted SC
    warminster
    yeah I def should have done flat or matte black...
  1. Painted the S/C, TB, etc..
    By colindunn in forum Visual/Body Modifications
    Last Post: 07-08-2010, 11:36 PM
  2. painted supercharger
    By gtpinsc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2010, 11:47 PM
  3. has anyone painted there own car?
    By beast55 in forum Visual/Body Modifications
    Last Post: 07-06-2009, 04:26 AM
  4. painted the TDC FWI.....
    By gotboost3 in forum Visual/Body Modifications
    Last Post: 05-16-2009, 07:35 PM
  5. polished------->painted
    By Kool Karl in forum Tires & Wheels
    Last Post: 01-14-2009, 12:08 AM
