Thread: My HIDs
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 78
  1. #1 My HIDs
    GT Level Member SliceTheRice's Avatar
    South Jordan, UT
    First of all, let me apologize because I'm sure the answers to my questions are wildly spread out all over the place. My problem is that for some reason the site is not letting me search "HID," or "hid." So after about an hour and a half of googling and reading posts in here I'm still left with questions and I don't have a lot of time left (my car is in the body shop and I want to replace the headlights with projectors instead of stockers and I need to do something very soon).
    I really want HIDs because everyone seems to swear by them. I've read that projectors are the way to go if you want HIDs. The problem is that I've seen a lot of people have a myriad of issues that I didn't even know existed. So if I were to get these, what would I need to know before hand?
    HID 97-03 PONTIAC GRAND PRIX HALO PROJECTOR HEADLIGHTS: eBay Motors (item 310228670918 end time Jul-21-10 18:45:03 PDT)
    Thank you all SO much for your help!
    2000 Pontiac Grand Prix GTP
    (3.4 MPS, DHP 1.0 tune, ZZP Plog & 3" DP, 2.5" cat-back exhaust, resonator delete, AL104 plugs, 180* T-stat, Falken Ziex 245/45/18 tires)
  2. #2 Re: My HIDs
    GT Level Member clevelandfan's Avatar
    ohio
    they look sweet. i want something like that too. i kno my buddy has an 03 impala wit halos, and they r nothing but wiring issues. but idk about these. gl either way
    97' Grand Prix. Blurring the lines between SE, and GT
  3. #3 Re: My HIDs
    South Jordan, UT
    Thanks man.
    One thing I'm not sure about is how just the halos and LEDs turn on. What would be sweet is if you could wire it so the DRLs were just the halos and LEDs and then the headlights were...well just the headlights at night, you know? I have no freaking clue how all this stuff works.
  4. #4 Re: My HIDs
    GT Level Member mezzoni's Avatar
    Nov 2009
    Milford, CT
    i too am interested in halos such as those but being the cheap person i am i wasnt gonna go with hid's. should i take the hit? and i totally agree with the having just halo's on during the day and actual headlights on at night. theres probably a write up on it somewhere on here though... also, will there be ANY fitment issues with those particular headlights posted in that link?
    2006 pontiac G6 GT coupe - the daily
    2001 pontiac trans am WS6 - pacesetter headers, slp exhaust, diablo sport tuner, ported throttle body, ported MAF, SLP intake lid, B&M shifter, UMI panhard bar, lowered on koni's
  5. #5 Re: My HIDs
    ohio
    the easiest way would be to wire them in with ur headlights. but if u wired em in with ur running lights, or fogs even, u could change it up some. just an idea
  6. #6 Re: My HIDs
    South Jordan, UT
    Are the issues people have more associated with trying to run HIDs in stock housings? I saw a lot of stuff with people having to figure out how the make the bulbs fit just like the halogens did, stuff like that....
  7. #7 Re: My HIDs
    Quote Originally Posted by SliceTheRice View Post
    I got the standard 9007 single beam HID kit with relay harness from vvme.com and the whole thing is plug and play. The light output is way better and the install took me around an hour because I never did it before.
  8. #8 Re: My HIDs
    ohio
    thats the way to go man. just use the 9007s and ur good
  9. #9 Re: My HIDs
    Highland Heights, KY
    DDM Tuning : HID Kits
    been running these a while on my motorcycle and my brother a few years on his Mazda protege... Excellent product and only 40
    takes 2minutes and is plug and play
  10. #10 Re: My HIDs
    West Side Michigan
    Here is my write up on these headlights and how they work:
    http://www.grandprixforums.net/f14/d...rkk-27293.html
    I have HID's in them and they work perfectly fine. Make sure you get an H3 HID kit because that is the type of bulb that these take for the low beams. Wiring is really easy too. I don't outline how to do the headlights, but I wouldn't mind showing you through PMs. The Headlight comes with it's own halogen bulb too, so you don't need to get HID's in them right away. I got my HID kit from VVME also, good quality and very happy with them.
  11. #11 Re: My HIDs
    Arizona
    Quote Originally Posted by 98GT3800 View Post
    what options should i do for these?
    bulb type?
    Harness?
    eliminator?
    '00 GT- nothing special
  12. #12 Re: My HIDs
    GTX Level Member 03GTPLE's Avatar
    Tyler, TX
    Quote Originally Posted by coreygnar View Post
    bulb type?
    Harness?
    eliminator?
    depending on what you are looking for, depends on what you choose. If you are just talking about using the stock housings use the 9007 bulb.
    If you get the dual hi/lo kit, it will come with the wiring harness, so you don't need to get it. The dual means the hi and low beams are HID. This is what I have and I didn't get an eliminator.
    If you get the single kit, the low will be HID and the hi will be halogen (regular bulb kind, just like you have now). You would then need to add on the harness for $15.
    *note* With the dual hi/lo HID bulb, the bulb has a magnet in it to move the filiment inside to change it to get a different point in the housing... bottom line is that the hi beams are worthless and I always keep them on lo. Also, I was parked next to a friends G8 GT and he couldn't get his hi or lo beams to overpower mine. I also drove 2000 miles from Colorado to Alabama and never wished I had a hi beam. Yes, I did drive at night.
    Read this thread for more info http://www.grandprixforums.net/f11/u...tml#post388548
    good kit, I'd recommend it. I have the 35W 5000K color as I hate the 6000k blue color.
    2003 White Grand Prix GTP Limited Edition
    - 3.4 pulley, tune by Boostd1/CLINT@AIR, Short Ram Intake, PLOG, 3" ZZP Downpipe, AL 104's, 180* t-stat, Impala STB & 12" cross drilled/slotted/zinc washed rotors, DDM HID's, and put in a heads up display for now...
  13. #13 Re: My HIDs
    99% of the 9007 HID bulbs are wrong... You have to mod them to get hte most output.
    The top of the flange to the middle of the filiment should be 1.75" but it probably wont be.
  14. #14 Re: My HIDs
    Tyler, TX
    yeah, hat Matt said is right. All the info is in the thread I posted above. The light output pic of mine is with them unmodded. I don't have plans on doing it either, but probably should.
  15. #15 Re: My HIDs
    Arizona
    what should i do 35 or 55w?
  16. #16 Re: My HIDs
    35, you dont need 55
  17. #17 Re: My HIDs
    Tyler, TX
    I went with 35 because I read that 55 could melt the housings. After I made the order I was reading that it really won't. So I can't really help ya there, personal preference... and I don't know what the extra $20 would get you since the light is off from the get go.
    oh yeah, took a long time to show up from DDM, about two weeks, if not a little longer. Combination of them having a sale, and order from Japan the same time the Toyota BS was going on. It took a long time to get through customs (according to the friendly rep at DDM)
  18. #18 Re: My HIDs
    just putting them in makes them worth your money and time.
    Modding them gives you that extra light output that makes you say "**** projectors".
    Though high beams would be nice...
  19. #19 Re: My HIDs
    Tyler, TX
    yeah, proper high beams would be nice, like on my truck.... oh well. At least I can see at night.
    I'm just afraid to mod them, screw it up, and then have worthless bulbs. ...ya know...
  20. #20 Re: My HIDs
    Its easy?
    steady hand and a dremel
  1. H3C Hids
    By Slueth66 in forum Visual/Body Modifications
    Last Post: 01-20-2010, 12:59 AM
  2. HIDS on
    Last Post: 12-15-2009, 12:47 AM
  3. What hids to go with???????????
    By IrishNation24 in forum Visual/Body Modifications
    Last Post: 06-26-2009, 12:36 AM
  4. Which Hids
    By krippled in forum General Tech Discussion
    Last Post: 01-31-2008, 11:17 PM
