Thread: Hid help
Results 1 to 14 of 14
  1. #1 Hid help
    SE Level Member Mrc728's Avatar
    Jun 2011
    Indiana
    SO Ive searched and searched about HIDs and cant find anything on the installation of these. I got the kit from vvme with the relay, I know where all the connections go except the two wires coming off the relay itself. Not the ground and positive, there are 2 smaller wires coming off of the blue connector. where do these go?
    Thank You
  2. #2 Re: Hid help
    The LED guy.... csssaint12's Avatar
    Nov 2009
    Duluth, Minnesota, United States
    Pics? Do you have the connectors between your old lights and the harness hooked up?
  3. #3 Re: Hid help
    Jun 2011
    Indiana
    Dont have anything hooked up yet just tryin to find out before i start
  4. #4 Re: Hid help
    Jun 2011
    Indiana
    IMAG0227 | Flickr - Photo Sharing!
    There is a red and black wire coming of the blue connecter not sure where these go, as you can see i have 3 blue connectors which ones do i hook up.
  5. #5 Re: Hid help
    Jun 2011
    Indiana
  6. #6 Re: Hid help
    St. Cloud, MN
    Take the harness off and plug it straight to your stock harness. You don't need a relay harness.
    But, that wire in your picture goes to nothing. Just leave it be.
  7. #7 Re: Hid help
    Jun 2011
    Indiana
    Got em hooked up, Is it normal for the ballast to buzz?
  8. #8 Re: Hid help
    Bunnell, FL
    the blue connector attached to the bulb does jack ****
    the one that is in the back right is for the relay harness. also the moment i get a pair of bulbs i cut that rubber circle out and remove the extra connector so there is not any confusion
    and i highly suggest a relay harness on any vehicle w/ a "conversion" kit like this one
    especially if you are leaving the drl enabled
    I'm a Sex Offender
  9. #9 Re: Hid help
    Bunnell, FL
    ^^^ that one the two is for bi-xenon bulbs
    I'm a Sex Offender
  10. #10 Re: Hid help
    St. Cloud, MN
    Quote Originally Posted by Mrc728 View Post
    Yes.
  11. #11 Re: Hid help
    Bunnell, FL
    and your copyright crap was easy to break
    I'm a Sex Offender
  12. #12 Re: Hid help
    GT Level Member tyv193's Avatar
    Jul 2010
    Central Ny
    I had that same problem with my harness. Gave up on it and plugged it into the stock harness.
    2002 GTP
  13. #13 Re: Hid help
    Jun 2011
    Indiana
    Yeah I hood it up without the harness, everything works great, no idea what u mean by my copyright crap.
  14. #14 Re: Hid help
    Bunnell, FL
    try and right clcik on the flikr image
    and good luck w/o the harness
    I'm a Sex Offender
hid
