Thread: retrofit headlights 04 to 08
Results 1 to 4 of 4
  1. #1 retrofit headlights 04 to 08
    SE Level Member carlover89's Avatar
    Sep 2011
    Sheboygan
    Does anyone retrofit headlights? How much do u charge?
  2. #2 Re: retrofit headlights 04 to 08
    Nobody offers the service on here that I know of that will do it for the 04-08s, but on hidplanet.com there is a few guys who offer services to retrofit headlights and I know one of them did the 04-08 headlights at some point. The problem is not just doing the headlights there is the setup process after with the black plastic behind the headlight that needs to be cut in most cases.
    Retrofitting isn't too hard though, its pretty easy, just do a lot of reading on it and follow along. Its a pretty straight forward process
  3. #3 Re: retrofit headlights 04 to 08
    Sep 2011
    Sheboygan
    id be a total noob at it... took a stab at opening up one headlight (had a extra set) and accidently mudalted it . I'd like it to look clean and i know i wouldn't be able to make it look as clean as id like. I'll take a look at hidplanet.com though. Thanks!
  4. #4 Re: retrofit headlights 04 to 08
    St. Cloud, MN
    Seriously, do it yourself. If you pay someone to do it for you, your paying almost as much as the dumb car is worth to have different headlights. It really isn't worth it.
  1. 04+ Projector Retrofit
    By Koniig in forum Visual/Body Modifications
    Last Post: 07-10-2017, 03:02 PM
  2. Retrofit help
    By DukesGTP in forum Visual/Body Modifications
    Last Post: 12-04-2011, 06:04 PM
  3. My Projector Retrofit
    By Dawings33 in forum 04+ Specifics
    Last Post: 09-06-2011, 09:49 PM
  4. Retrofit help
    By GPGT2004 in forum Visual/Body Modifications
    Last Post: 07-07-2011, 03:12 PM
  5. BoostJunki3 Retrofit Set #1
    Last Post: 03-06-2011, 05:42 PM
