Thread: HID Suggestions for 02 Grand Prix
Results 1 to 9 of 9
  1. #1 HID Suggestions for 02 Grand Prix
    SE Level Member Mrc728's Avatar
    Jun 2011
    Indiana
    Tired of my stock headlights being so dim, so i want to buy a HID kit and need a little help. Im thinking this kit if its right HID Kits, BMW Aftermarket Bumpers & Lighting, DEPO - DDM Tuning
    and do I need the HID harness?
    And what bulb do I need for the stock housings.
  2. #2 Re: HID Suggestions for 02 Grand Prix
    Omaha, NE
  3. #3 Re: HID Suggestions for 02 Grand Prix
    Bunnell, FL
    I'm a Sex Offender
  4. #4 Re: HID Suggestions for 02 Grand Prix
  5. #5 Re: HID Suggestions for 02 Grand Prix
    Jun 2011
    Indiana
    Read through all the forums i could find, I need the 9007 bulb, but still confused with the relay harness, some people say definitley need it but the ddm site says i dont, what do you think?
  6. #6 Re: HID Suggestions for 02 Grand Prix
    Relay kit just prevents them from flashing and not turning on at start up...
    I don't have the relay kit in any car...just flick teh brights a few timez.
    Done.
    They power up.
    Saves you 20 bucks.
  7. #7 Re: HID Suggestions for 02 Grand Prix
    Jun 2011
    Indiana
    Also just read to get the relay if you have daytime running lights, I have disconnected mine so im thinking i dont need it.
  8. #8 Re: HID Suggestions for 02 Grand Prix
    GT Level Member chamilton89's Avatar
    Columbus, Ohio, United States
    I have a 2002 GP, and I did upgrade the headlights to HID's from DDM, exactly the same as you are planning to do. The HID harness (which I have) has a relay in it which is controlled via the current headlight harness (well actually only one side) but never the less, this harness is connected directly to your battery, thus you don't have to trust on the current GP wiring to power the HID's ballast. The DRL's have nothing to do with the relay kit, they will still power on the HID's when the DRL's are on, so you will have to pull the DRL diode, which it looks like you have already done. All that being said, if you plan on getting a hi/low set of 9007 HID's (which I have) then you will need the harness to control the functionality, but this set automatically comes with the harness, so no need to order a second. So, long story short. Harness is precautionary, not necessary, but I would air on the side of caution and make sure your ballasts are getting the voltage they deserve but running the relay harness.
    Infinity all around.
  9. #9 Re: HID Suggestions for 02 Grand Prix
    Jun 2011
    Indiana
    Decided to get the harness with the vvme kit, an extra 10 bucks not to bad to be on the safe side and not worry about it
    Thanks for the help.
  1. Grand prix GT side skirts on 97 Grand Prix SE
    By Carnes97SE in forum How To Write-Ups/Tech Tips
    Last Post: 11-17-2013, 05:17 PM
  4. Freeze Plug Suggestions: 1999 Grand Prix
    By Oklahoma Traveler in forum General Tech Discussion
    Last Post: 07-07-2011, 01:16 PM
  5. Will a 04 grand prix 3800 engine fit into a 01 grand prix
    By jordan61488 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-24-2010, 01:01 AM
