Thread: Adaptive Front Seats
Results 1 to 16 of 16
  1. #1 Adaptive Front Seats
    GTP Level Member
    Pittsburgh
    So this is a long post but a pretty cool mod if you ask me.
    Cadillac Developed a seating system that has a series of 10 Air Blatters and uses 8 air pressure sensors that monitor the pressure in the blatter and then readjust every 4 minuets. There are a few different modes as well. There is off, AUTO, and lumbar only. so when the system is in auto, then the system goes to work making the occupant comfportable. lumbar only uses the air blatters in the backrest of the seat to give you your support.
    it was a option that added $1,650 to the vehicle way back in 1998-2000.
    anyway onto the pics
    here is all the parts layed out on the table in Trim
    the seat with the bottom cusion ff
    back of the seat showing the lumbar
    there is the leather off and the blatters mocked up in place
    Back of the seat showing the Moudule and the pump for the blatters
    the module mocked up in place with the pump
    the bottom bags glued in place (using he same arear the GM used for bag movement)
    because the Caddy has a different seat cusion design i had to be creative so i took some Last and sewed it into the plastic lumbar plate, so the orignal seat cusion will stick to it
    here is the back bags glued in place
    i did have to modify the hook and loop of te seat cover so the air lines can get o the correct place
    and the money shot. The completed seat with the blatters and the cover reinstalled
    adjustable bolsters not only in the backrest but in the bottom cusion.....ya eat your heart out AL7's
    2003 SSEi,
  2. #2 Re: Adaptive Front Seats
    Wanna do mine now?
  3. #3 Re: Adaptive Front Seats
    Awesome write-up man, gonna sticky this!
  4. #4 Re: Adaptive Front Seats
    GTP Level Member
    Pittsburgh
    It's really like sitting on a pillow but getting amazing support in the corners
    2003 SSEi,
  5. #5 Re: Adaptive Front Seats
    Oct 2011
    Toledo, OH
    blaDDer
    7"
  6. #6 Re: Adaptive Front Seats
    Feb 2010
    TN
    Great write up but a few quick questions
    1.) What make and ,models caddie had this option, or where go we get them from? Makes it easier when we hit the junk yards.
    2.) Did you take the foam and all and transfer them to a grand prix seat, or did you put a caddie seat in your Grand prix
    Thanks
  7. #7 Re: Adaptive Front Seats
    Waukesha, WI
    subd
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  8. #8 Re: Adaptive Front Seats
    utah
    Subd
  9. #9 Re: Adaptive Front Seats
    GTP Level Member
    Pittsburgh
    Quote Originally Posted by Logan541 View Post
    Thanks
    The bladders, module, and pump came from a 98-2000 Seville STS with the Adptive Seat option. It has to say "AUTO" on the lumbar switch that is located onto the seats. Both the passenger and driver units were pulled from a junkyard
    the Foam is the OEM from My Bonneville. But could be adapted to any car with some enginuity.
    and the wiring is very simple, its Power, Ground and Ign 3 to make the module activate
    2003 SSEi,
  10. #10 Re: Adaptive Front Seats
    Feb 2010
    TN
    Quote Originally Posted by 2003 SSEi View Post
    Thanks for clearing that up well its off to the junkyard for me, Everytime I think I am finished with my car someone like you runs a post that creates more work for me lol.
  11. #11 Re: Adaptive Front Seats
    GTP Level Member buickman104's Avatar
    NYC
    Looking forward to someone doing this to GP wooden bench seats. Maybe I won't have to switch to Regal seats to be comfy in my GTP!
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  12. #12 Re: Adaptive Front Seats
    P... I was on vacation and didn't it that you had it done. Awesome job as usual. Got both completed?
    And yes..when I get there in June, I'm kinda expecting you or I to have a set for the Regal by then. It's going in. I'm missing the Bonneville AL7's still... W body seats (unless you talk 90 turbo car seats) suck monkey butt.
  13. #13 Re: Adaptive Front Seats
    Never Never Land
    Would Deville seats work as well? The lumbar says auto so I would think that it would work. Here's a pic...
  14. #14 Re: Adaptive Front Seats
    GTP Level Member
    Pittsburgh
    yes, just cut the leather carefully and check for the Bladders
    2003 SSEi,
  15. #15 Re: Adaptive Front Seats
    Jun 2012
    Buckeye Lake, Oh
    Neat idea. Have to look into it. Have a bad shoulder that could us some extra support.
  16. #16 Re: Adaptive Front Seats
    Donating Users timboku's Avatar
    Montgomery, IL
    Gonna try this on my 06 gp seats. Would the bladders go over the heat element and work? Also, where did you mount the switch for this? Just wondering.
    thanks
  1. Torx size for front seats
    By Joe in forum General Tech Discussion
    Last Post: 10-15-2009, 04:21 PM
  2. Taking Front Seats Out
    By MysticStyl3z in forum General Tech Discussion
    Last Post: 07-30-2009, 11:27 PM
