Thread: Best aftermarket headlights for 04+ (not going to retro)
Results 1 to 10 of 10
  1. #1 Best aftermarket headlights for 04+ (not going to retro)
    GT Level Member dengnath's Avatar
    I just need to know which are the best housings that aren't going to fog up, and aren't going to start peeling after a year (like my last ones).... they are not going to be retroed, they are just going right on the car. Any help would be great! thanks
  2. #2 Re: Best aftermarket headlights for 04+ (not going to retro)
    GTP Level Member joshv's Avatar
    canada
    i have seen oem with chrome on the inside they look really good, imo
    2005 GXP / Cartuning Turbo Kit / meth / Cutout / Ported LS4 intake Manifold / HP Tuned / Custom 3" Cat-Back / Highflow Cat / SSC Springs / Poly Dogbone Mount's / 2nd Tranny /
    ( p/o track time12.6@109mph 1.7 60ft )
  3. #3 Re: Best aftermarket headlights for 04+ (not going to retro)
    most of my car is silver and black so I'm going to stick with black.... i thought a lot about the chrome.... but nothing else on my car is chrome. I am just looking at this point for something that is going to hold up good.... i paid 100 dollars for my last set and they fogged up constantly
  4. #4 Re: Best aftermarket headlights for 04+ (not going to retro)
    Kansas
    You want the best housing? Stock, hands down. Even if you had to sand them down every so often and throw some clear on them. You want the best light output? One word, retro. Know you're not wanting to retro, but stating the obvious here.
  5. #5 Re: Best aftermarket headlights for 04+ (not going to retro)
    I have tried to go down the retro road and i simply am not throwing 3-5 hundred dollars into a retro.... because when i do something i do it right so i know it would run atleast 500. I want the BEST AFTERMARKET (OEM LOOKALIKE) HOUSING. I thought about getting oem ones from pfyc.com but the are 400 dollars. I would like to stay under 200..... no sanding, no clear coating
  6. #6 Re: Best aftermarket headlights for 04+ (not going to retro)
    GTP Level Member Javi's Avatar
    OKC, Oklahoma
  7. #7 Re: Best aftermarket headlights for 04+ (not going to retro)
    Quote Originally Posted by Javi View Post
    Ordered...oh wait what :hide:
    My after market headlights are still good 1.5 years later, you should just make sure you rub plastiX on them and wax them on occasion and you won't have a problem. They should be fine.
  8. #8 Re: Best aftermarket headlights for 04+ (not going to retro)
    Bunnell, FL
    Quote Originally Posted by dengnath View Post
    ya good luck with that
    I'm a Sex Offender
  9. #9 Re: Best aftermarket headlights for 04+ (not going to retro)
    Kansas
    I did my retrofit including Morimoto HID bulbs and ballasts (~$150) and new headlight housing all for under $400 bucks.
  10. #10 Re: Best aftermarket headlights for 04+ (not going to retro)
    Kansas
    I had mine painted and cleared after my retro.
  1. Picking the best aftermarket headlights
    By Haleys99GTP in forum Visual/Body Modifications
    Last Post: 09-23-2010, 07:49 AM
  2. aftermarket headlights
    By rmil03 in forum Visual/Body Modifications
    Last Post: 09-16-2010, 11:47 PM
  3. Aftermarket headlights quality
    By Haulero in forum General Tech Discussion
    Last Post: 05-03-2010, 08:36 PM
