Thread: HID Help
Page 1 of 3 123 LastLast
Results 1 to 20 of 60
  1. #1 HID Help
    GT Level Member tyv193's Avatar
    Jul 2010
    Central Ny
    Ive searched on the forum and google and can't figure out how to wire this kit. Its probably something simple but I have never done anything like this.
    The plug that is coming from the bulb that has no where to hook into, where does that go? Not the blue piece that goes in to the stock plug but the other one. And also where does the blue piece that is on the harness where does that plug into? Thanks.
    2002 GTP
  2. #2 Re: HID Help
    are you talking about the one with the yellow on it?. if so you wont use it because of your relay harness
    SMGPFC Member #10
  3. #3 Re: HID Help
    Jul 2010
    Central Ny
    ok thanks. what about the blue one in the top middle?
    2002 GTP
  4. #4 Re: HID Help
    stock connector, just like the one on the bulbs
    SMGPFC Member #10
  5. #5 Re: HID Help
    Jul 2010
    Central Ny
    ok thanks man
    2002 GTP
  6. #6 Re: HID Help
    not a problem,, let me now if you have any more questions
    SMGPFC Member #10
  7. #7 Re: HID Help
    Jul 2010
    Central Ny
    where does it plug into and where do you wire the two wires coming from it? its not the same as the blue one at the bottom of the picture. the one like like the one at the bottom is not visible.
    2002 GTP
  8. #8 Re: HID Help
    Jul 2010
    Central Ny
    also the wires that run to the battery the connector on the end is too small to fit?? am i doing it right
    2002 GTP
  9. #9 Re: HID Help
    that other blue plug should go to the factory connector..can you try and get a better pic of it?...and my battery connectors were to small too, i cut it and pulled it apart to make it work
    SMGPFC Member #10
  10. #10 Re: HID Help
    Jul 2010
    Central Ny
    ill go take a picture
    2002 GTP
  11. #11 Re: HID Help
    Grand Pricks cameron92's Avatar
    May 2011
    Orangeville, Ontario, Canada
    heres how I did it.
  12. #12 Re: HID Help
    Jul 2010
    Central Ny
    This is the connector im talking about in a close up
    but this is a little different than the other two blue connectors. there is one that goes to the drivers side headlight that is connected. This is near the passenger side light near the wires that would connect to the battery. In the picture i have the other blue connector already plugged into the light.
    2002 GTP
  13. #13 Re: HID Help
    Jul 2010
    Central Ny
    Ok, thank you I understand now. I appreciate all your help guys.
    2002 GTP
  14. #14 Re: HID Help
    i dont think that those matters,
    SMGPFC Member #10
  15. #15 Re: HID Help
    May 2011
    no problem, what K hids did you get?
  16. #16 Re: HID Help
    Jul 2010
    Central Ny
    I got 6000k
    2002 GTP
  17. #17 Re: HID Help
    May 2011
    nice, post a pic after, i wanna see 6000k, i bought 10,000k for some reason( stupid mistake) but they look like 8000k.
  18. #18 Re: HID Help
    Jul 2010
    Central Ny
    ok ill post a pic tomorrow after finish
    2002 GTP
  19. #19 Re: HID Help
    Jul 2010
    Central Ny
    The headlights wont turn on now..
    2002 GTP
  20. #20 Re: HID Help
    lol...
    are they hooked up right?
    SMGPFC Member #10
hid
