Thread: HID Help
Page 3 of 3 FirstFirst 123
Results 41 to 60 of 60
  1. #41 Re: HID Help
    GT Level Member tyv193's Avatar
    Jul 2010
    Central Ny
    they are 35 watt. the blue connector you told me to plug in this last time has to wires comming off the two outside prongs maybe they have to be grounded? ik i turned the key nothing..
    2002 GTP
  2. #42 Re: HID Help
    maybe?...or maybe those are what plug in the factory plug....ive never seen a relay harness like that before..try getting on this and see if it helps..it helped me the first time
    DDM Tuning - Help Desk Software powered by DDM Tuning
    SMGPFC Member #10
  3. #43 Re: HID Help
    Jul 2010
    Central Ny
    ok i got the passenger side to work but the drivers side wont turn on and ik the bulb is ok because it works through the factory wiring... my relay harness only has one ground. there are two wires in one place they arent seperate like the kit you showed
    2002 GTP
  4. #44 Re: HID Help
    mine does that sometimes, did you tring the lights on and off a couple times?..thats what fixs mine and i found out that it was the ground doing it so i grinded some paint off to make the ground better and havent had a problem since
    SMGPFC Member #10
  5. #45 Re: HID Help
    Jul 2010
    Central Ny
    my drivers side comes on for abour 5 seconds then shuts off? maybe more like 2 seconds
    2002 GTP
  6. #46 Re: HID Help
    Jul 2010
    Central Ny
    reversing polarity doesnt work either..
    2002 GTP
  7. #47 Re: HID Help
    Grand Pricks cameron92's Avatar
    May 2011
    Orangeville, Ontario, Canada
    i have mine hooked up exactly like you see in the picture i labeled and it works perfectly. i dont have slim ballasts but i dont think that would make a difference
  8. #48 Re: HID Help
    Jul 2010
    Central Ny
    i have slim ballasts. i tried the way you hooked yours up and i get nothing.
    2002 GTP
  9. #49 Re: HID Help
    May 2011
    ill go get a pic of mine, hold on.
  10. #50 Re: HID Help
    Jul 2010
    Central Ny
    let me know when ya get a picture
    2002 GTP
  11. #51 Re: HID Help
    still having problems?
    SMGPFC Member #10
  12. #52 Re: HID Help
    Jul 2010
    Central Ny
    yea i cant the drivers side light to stay on. when your first start the car up it comes on for a second then shuts off
    2002 GTP
  13. #53 Re: HID Help
    so you got the running again..thats good..and you check your powers and grounds?...then i would say that the bulb is the problem now
    SMGPFC Member #10
  14. #54 Re: HID Help
    Jul 2010
    Central Ny
    yea i re did the grounds and the bulb works fine when running through the stock wiring
    2002 GTP
  15. #55 Re: HID Help
    ok then, does it attempt to re light, or is it more dead and gone, after it goes out is the ballest still working or does it cut out to?..
    SMGPFC Member #10
  16. #56 Re: HID Help
    Jul 2010
    Central Ny
    the ballast stops whining
    2002 GTP
  17. #57 Re: HID Help
    then its the wiring between the ballest and the souce..so what is powering the ballest?..the long wires coming from the relay that stretch across the car, check those and make sure those wires are ok, not pinched or cut or something like that
    SMGPFC Member #10
  18. #58 Re: HID Help
    Jul 2010
    Central Ny
    ok, eventhough it comes on for a second ? then goes out?
    2002 GTP
  19. #59 Re: HID Help
    yea that means that the voltage is flowing but then stops, so its more like high resistance,, most likey on the ground side..9 times out of 10 its the ground ciruit
    SMGPFC Member #10
  20. #60 Re: HID Help
    Jul 2010
    Central Ny
    okk ill keep playing with it
    2002 GTP
hid
