Thread: HID Help
Results 21 to 40 of 60
  1. #21 Re: HID Help
    GT Level Member tyv193's Avatar
    Jul 2010
    Central Ny
    I did it how cameron put in the picture above
    2002 GTP
  2. #22 Re: HID Help
    Jul 2010
    Central Ny
    is it suppose to be grounded somewhere?
    2002 GTP
  3. #23 Re: HID Help
    try wiring it up without the relay harness, first then hooking up the harness
    and yes the black wires go to ground
    SMGPFC Member #10
  4. #24 Re: HID Help
    Jul 2010
    Central Ny
    ill try it without the harness
    2002 GTP
  5. #25 Re: HID Help
    Jul 2010
    Central Ny
    they work with the stock wiring but not with the harness. maybe im not getting a good connection from the battery?
    2002 GTP
  6. #26 Re: HID Help
    you have a have a good ground on the harness and the bulbs
    SMGPFC Member #10
  7. #27 Re: HID Help
    Jul 2010
    Central Ny
    so you think the harness doesnt have a good ground?
    2002 GTP
  8. #28 Re: HID Help
    yea...
    heres were my grounds are
    SMGPFC Member #10
  9. #29 Re: HID Help
    Jul 2010
    Central Ny
    what am I wiring there tho? sorry im confused
    2002 GTP
  10. #30 Re: HID Help
    the ground on the harness, on one side and the ground on the bulb on the other side, then the power(red) on the top post on the fuse block
    SMGPFC Member #10
  11. #31 Re: HID Help
    Jul 2010
    Central Ny
    ok i wired the ground to the battery negative... thanks man
    2002 GTP
  12. #32 Re: HID Help
    not a problem, keep me updated
    SMGPFC Member #10
  13. #33 Re: HID Help
    Jul 2010
    Central Ny
    still not turning on must be something else wrong
    2002 GTP
  14. #34 Re: HID Help
    try this
    if theres a ? then its not used
    SMGPFC Member #10
  15. #35 Re: HID Help
    Jul 2010
    Central Ny
    i did that and it didnt work and the car wouldnt start so i switched it back and now it will
    2002 GTP
  16. #36 Re: HID Help
    Jul 2010
    Central Ny
    the one that you told me to plug in has two little wires coming off of it.. what should i do with those a red and a black. idk what it was doing but the car wasnt getting any power
    2002 GTP
  17. #37 Re: HID Help
    i have no clue what those are for as long as your giving the relay a power and ground then it shouldnt matter,,,the car isnt getting power?..what?..like the batterys dead
    SMGPFC Member #10
  18. #38 Re: HID Help
    Jul 2010
    Central Ny
    yea like it wouldnt turn over plugged in like that
    2002 GTP
  19. #39 Re: HID Help
    Jul 2010
    Central Ny
    i feel like just running them on stock wiring but ik i shouldnt
    2002 GTP
  20. #40 Re: HID Help
    well that doesnt make any since...youu couldnt start your car with it plugged in?..what about it unplugged?....
    that blue piece should go to the factory plug..something on that harness has to plug into the factory wiring.
    is fine on your stock wiring..are they 55w?...i wouldnt keep it like that but its fine for a little while
    SMGPFC Member #10
hid
