Thread: sunroof wont close completely
Results 1 to 10 of 10
  1. #1 sunroof wont close completely
    Jun 2011
    canton ohio
    Ok my sun roof was haveing trouble opening and closing so I put white lithium grease on it and it worked perfect for 2 days. Today I went to close it and the back is coming down before it should and scratching my roof. It slides almost shut then just stops no noise or nothing. Leaves about a quarter inch gap in the back. Please help it raining. I stuck my spare tire on it to kinda hold it closed. Any help on how to fix will be greatly appreciated.
  2. #2 Re: sunroof wont close completely
    Jun 2011
    canton ohio
    Any help?
  3. #3 Re: sunroof wont close completely
    GTP Level Member SnowDrift's Avatar
    Apr 2009
    Central Ohio map dot.
    The manufacturer recommends a SMALL amount of graphite, opposed to grease for the lubrication. Aside from that, I think you might need to look at the adjustment. It sounds as if it's too far one direction, causing it to bind.
    If there's a 1/4" gap in the back, then that's WAY too much and it actually sounds as if the seal is missing. It should be tight enough all the way around that you cannot slide a piece of paper out of it with it closed.
  4. #4 Re: sunroof wont close completely
    Jun 2011
    canton ohio
    No all seals are there and I meant sticking up above roof
  5. #5 Re: sunroof wont close completely
    GT Level Member tcman49's Avatar
    Apr 2011
    Palm Coast, Florida
    hopefully you are in southern california because the song says it never rains there
  6. #6 Re: sunroof wont close completely
    Jun 2011
    canton ohio
    Unfortunately ur joke isn't funny
  7. #7 Re: sunroof wont close completely
    Apr 2009
    Look at the adjustment screws on the sides. There are four (I think that quantity is right) screws that allow adjustment up and down. They may be loose or may just need adjusted down. They're slotted holes and if loose, could cause what you're describing.
  8. #8 Re: sunroof wont close completely
    Jun 2011
    canton ohio
    Thanks I will check that and see.
  9. #9 Re: sunroof wont close completely
    GT Level Member sic6's Avatar
    san marcos, tx
    Check the track where the glass slides through. I bet the plastic part of it is cracked or broken. I had this same issue a while back. Tried adjusting it numerous times with no luck. It will probably have to be replaced. Check your local salvage yard or Morad parts for a replacement.
  10. #10 Re: sunroof wont close completely
    Jul 2013
    Missouri
    any results? I recently picked up a 98 with the symptom you described. The sunroof appears (and sounds) like it is moving properly but it won't go copmletely forward enough to suck the rear down into place (about a 1/4" shy). it is also dragging or scratching the paint on the roof. I'm curious what it ended up being. thanks!
  1. Completely lost now please help. :)
    By Subzero121800 in forum Audio, Security & Visual Electronics
    Last Post: 12-01-2010, 10:52 AM
  2. Completely ruined GTX :(
    By SomeDudeAtHome in forum The Rant Forum
    Last Post: 11-14-2010, 06:41 PM
  3. And now for something completely different.... AED spoiler
    By BlownBigBlock in forum Visual/Body Modifications
    Last Post: 11-29-2009, 03:46 AM
  4. Completely Disabling ABS?
    By SuperSport in forum Brakes/Suspension/Chassis
    Last Post: 06-28-2009, 12:03 AM
  5. sunroof wont open
    By whitegtp in forum General Tech Discussion
    Last Post: 03-24-2009, 08:08 PM
