Thread: Cutting a hole in the roof
Results 1 to 20 of 30
  1. #1 Cutting a hole in the roof
    Bunnell, FL
    ANy one add the stock sunroof to a car w/o it?
    I'm a Sex Offender
  2. #2 Re: Cutting a hole in the roof
    From what I understand it can be a pain to get them to seal sometimes.
  3. #3 Re: Cutting a hole in the roof
    Akron Ohio
    Someone replaced the whole roof.
  4. #4 Re: Cutting a hole in the roof
    Bunnell, FL
    links and pics? i assume gm wasnt nice like mopar was and made the same roof w/ the hole already there just need to cut
    I'm a Sex Offender
  5. #5 Re: Cutting a hole in the roof
    Waukesha, WI
    ill say its easier to install a new roof instead of cutting the hole bracing it and trying to get it to seal
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  6. #6 Re: Cutting a hole in the roof
    GTX Level Member real diehl's Avatar
    Salina, KS
    Better yet, don't do anything.
    Sunroofs aren't that cool.
    signature removed for inappropriate content.
    -bio
  7. #7 Re: Cutting a hole in the roof
    They just make the car less ridged.
  8. #8 Re: Cutting a hole in the roof
    Waukesha, WI
    hm put ttops in?
    RayRay
    92 Turbo miata
    02 lexus is300
  9. #9 Re: Cutting a hole in the roof
    its AWDsome JarenSTi's Avatar
    Hawaii
    Quote Originally Posted by redlinepontiac View Post
    hm put ttops in?
    do it.
    2002 WS.6- exhaust, 42k miles
    2005 Subaru WRX
    2002 GT - sold
  10. #10 Re: Cutting a hole in the roof
    You had better have subframe connectors...
  11. #11 Re: Cutting a hole in the roof
    Bunnell, FL
    thats what roll cages are for
    I'm a Sex Offender
  12. #12 Re: Cutting a hole in the roof
    Right....
    they're not at ALL for protecting the occupant from the imminent roof collapse due to expressively high speeds.
  13. #13 Re: Cutting a hole in the roof
    GT Level Member neel2008's Avatar
    Huntington, IN
    T tops would be pimp....
    97gtp
  14. #14 Re: Cutting a hole in the roof
    Quote Originally Posted by z3r0 View Post
    LULz...you kidding.
    Right?
  15. #15 Re: Cutting a hole in the roof
    Never Never Land
    whole roof is easier AND seals properly...ill probably be doing it sometime
  16. #16 Re: Cutting a hole in the roof
    GT Level Member jmoore4294's Avatar
    Forget the sunroof. Just one more thing that creaks on these cars and will drive you nuts.
  17. #17 Re: Cutting a hole in the roof
    Bunnell, FL
    LULz...you kidding.
    Right?
    why, you don't understand that the proper installation and design will make the car more rigid?
    I'm a Sex Offender
  18. #18 Re: Cutting a hole in the roof
    Sure...........
    But you're better off investing in having SFC's fabbed and strut tower braces.... not these weak bars we have.
  19. #19 Re: Cutting a hole in the roof
    I do...but do you understand the money you put into a roll cage...
    You could buy another capable platform unlike a WBody?
    Just putting that out there for you to sit on.
  20. #20 Re: Cutting a hole in the roof
    SE Level Member woodyardweldor's Avatar
    Apr 2011
    USA
    The roof can be unbolted and a panel with sunroof installed it also has very strong glue / sealent along the seams. you will also need to take the windshield and back glass out and reseal them.
  1. cutting out under a load
    By re209 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-17-2011, 02:02 PM
  2. hole in VC
    By gtpinsc in forum General Tech Discussion
    Last Post: 01-23-2011, 10:50 AM
  3. radio cutting out
    By gtcoup in forum Off Topic Discussion
    Last Post: 12-26-2010, 01:25 AM
  4. ses codes and car cutting out
    By Xhondaguy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-18-2008, 12:33 PM
  5. Car Cutting out
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 03-31-2008, 04:48 PM
