Thread: 4th brake light
Results 1 to 7 of 7
  1. #1 4th brake light
    festus
    i was wondering what you all would think about cutting the pontiac part out of the back bumper and put a trailer brake light behind the bumper and tap into the 3rd brake light so when i hit the braks and the light comes on it shines threw the cut out pontiac text and lights up
  2. #2 Re: 4th brake light
    if i were to do something like that i would make it just a running light, not a brake light, that way its on all the time when you drive at night.
  3. #3 Re: 4th brake light
    festus
    i could get ia trailer light with multiple functions so i coul run it off the tail lights and it gets brighter when i hit the brakes
  4. #4 Re: 4th brake light
    yup. but then you would need to box in the lights, and 2 sets of lights or 1157 and a red lens or something like that, sounds like some work, you don't want to see the light coming out from the bumper cover if ya know what i mean ..some kind of red led's would do the trick maybe. sounds like it would be cool to do but there will be some kind of fab work even after you cut the letters out.
  5. #5 Re: 4th brake light
    I'd suggest against it. You'd need to seal it, cut it and then mod the bumper etc. Overall it would take a top notch body guy to make it look good.
    I have some experience behind this kind of stuff. Here's a Bonneville rear tail light. After opening it up, removing a layer of plastic off the back and then painting the lettering back in.. you can light them up. But..it's not for everyone.
    Not my best pics..but hey..lol
    And how you might look until you buy a face shield or sit a shop vac next to the dremel.
  6. #6 Re: 4th brake light
    Bunnell, FL
    sub'd
    I'm a Sex Offender
  7. #7 Re: 4th brake light
    GTP Level Member 2001goldGTP's Avatar
    california
    I have thought of doing this as well, but i would like another bumb to play with, keep my factory stuff nice just in case, and i would use and LED strip on neon light to light it up and make it a running light
    xp'd
  1. Trac off light, Brake light on?
    By 1badregal in forum Brakes/Suspension/Chassis
    Last Post: 10-17-2010, 10:24 AM
  2. Water in LR brake light housing/ABS light
    By andante147 in forum General Tech Discussion
    Last Post: 05-31-2010, 08:01 PM
  3. e-brake light
    By PNIGZ in forum Brakes/Suspension/Chassis
    Last Post: 02-26-2010, 06:12 PM
  4. my 4th brake light and 3rd reverse light
    By HART in forum Visual/Body Modifications
    Last Post: 11-05-2009, 01:33 PM
  5. Third Brake Light & LED's
    By Metallistar in forum Audio, Security & Visual Electronics
    Last Post: 05-29-2009, 11:06 PM
