Thread: replacing bumper cover
Results 1 to 5 of 5
  1. #1 replacing bumper cover
    pennsylvania
    my new bumper cover is on the way. How easy is it to replace? Also anyone knows any good sites for me to paint it. Its already primed so i should probably just wetsand with 1000 grit spray my black maybe wetsand again spray and the wait how long to clear it? then wetsand clear and polish it
  2. #2 Re: replacing bumper cover
    Donating Users BoostnBlackGTP's Avatar
    Waterloo, Iowa
    it is very easy to replace man. Open your hood and rigth above the grills u will see 3 push pins. Snap those out. Then look in the fenderwell u will see 1 bolt holding the bumper to the fender. and liek 3 screws on each side holding it to the fenderwell. And dont forget to unplug your fog light bulbs or take your fogligths out before you do it
  3. #3 Re: replacing bumper cover
    pennsylvania
    sounds good the fiberglass is so busted up on the one on it now. Hipefully plastic holds up better. I couldn even put my new lower grills in yet
  4. #4 Re: replacing bumper cover
    Grand Island, Nebraska
    The only tricky part is you will see like a while triangle inside the fender, that doesnt come off. the bumper slides out forward. also there are like 8 push pins in the lower facia if its a GT/GTP bumper.
  5. #5 Re: replacing bumper cover
    pennsylvania
    yea its a gtp so 8 push pins under it to k thanks
  1. Replacing valve cover gasket
    By Haulero in forum General Tech Discussion
    Last Post: 12-17-2010, 11:29 PM
  2. SE Rear Bumper/GT front bumper cover...
    By Mad Monkey in forum Visual/Body Modifications
    Last Post: 05-01-2010, 07:14 PM
  3. 04 GP Bumper Cover
    By 59VetteFI in forum Visual/Body Modifications
    Last Post: 03-12-2010, 10:37 AM
  4. Front Bumper cover 01 GTP
    By timmaayy2323 in forum General Tech Discussion
    Last Post: 02-27-2010, 10:35 PM
  5. Front bumper cover
    By mminchau in forum Visual/Body Modifications
    Last Post: 07-27-2009, 04:54 PM
