Thread: Cleans Official Retrofit Thread. Pictures of Work.
Page 24 of 24 FirstFirst ... 14222324
Results 461 to 476 of 476
  1. #461 Re: Cleans Official Retrofit Thread. Pictures of Work.
    Banned
    Mansfield, Ohio
    Quote Originally Posted by dengnath View Post
    Hey clean..... i can't get a straight answer on what to use. What do you use to "glue" your projectors to the reflectors and housing?
    I don't do retro's involving a "refelector shield" for gp's so I'm not sure I can answer that for you dengnath. IMO jb stick would mold around the projector bowl nicely to hold things securely but that is totally up to you!
  2. #462 Re: Cleans Official Retrofit Thread. Pictures of Work.
    Banned
    Mansfield, Ohio
    Someone explain to me why there's 6000 different methods on retrofitting 04+ projectors that one looks like this.....
    With a good size hole cut in the reflector and the projector sticking so far back in the housing.....
    To this washer/locknut method and the projector not touching the lense whatsoever....
    Second way would allow total rotational adjustment from the back of the projector and it's plenty far away from the lense it isn't going to melt anything. Two totally different methods is what I don't really understand...... 04+ guys should be doing with method number 2 imo....
  3. #463 Re: Cleans Official Retrofit Thread. Pictures of Work.
    Nov 2008
    Waterloo, Iowa
    With that in mind, can't you retro 04+ headights, and then once sealed, the owners would be able to rotate them on their own?
  4. #464 Re: Cleans Official Retrofit Thread. Pictures of Work.
    Banned
    Mansfield, Ohio
    Exactly that's what I'm getting at the 2nd method would allow for that.... I don't not for the life of me see why the projector has to sit that far back in the first method.........
  5. #465 Re: Cleans Official Retrofit Thread. Pictures of Work.
    GT Level Member Tommyp2010's Avatar
    Poland, Ohio
    from what I've been told if you don't cut out a bigger hole in the back you won't have room to put the shroud on, plus some people like to have the projector sit more flush with the back of the headlights.
    2006 Mitsubishi Evo IX MR
  6. #466 Re: Cleans Official Retrofit Thread. Pictures of Work.
    Banned
    Mansfield, Ohio
    Quote Originally Posted by Tommyp2010 View Post
    You'd have plenty of room to put a shroud on that.... Not to mention you're only going to gain roughly an inch buy cutting the hole bigger and then on top of it you make mounting it wayyy more difficult. Only way to mount it then is to gob it with jb stick....
  7. #467 Re: Cleans Official Retrofit Thread. Pictures of Work.
    top 5 dead or alive OmegaRed's Avatar
    Feb 2010
    Medford, Oregon, United States
    ill be a test subject, im gonna order some mini's on friday and ill try both ways and take pics of the projector in the headlight with no cutting... maybe it will work fine =)
  8. #468 Re: Cleans Official Retrofit Thread. Pictures of Work.
    GT Level Member dengnath's Avatar
    he cut he just cut a lot less.... he uses the washer as the back of the bowl instead of the original back of the hole.
  9. #469 Re: Cleans Official Retrofit Thread. Pictures of Work.
    Poland, Ohio
    thinking about going for round 2 of this since round 1 didn't work out so well. where do you guys get your headlight housings? The one's I had last time had some really hard sealant that was extremely difficult to pull apart, the OEM ones I did one time were much easier and had a nice soft sealant.
  10. #470 Re: Cleans Official Retrofit Thread. Pictures of Work.
    TYC's off rockauto or amazon,
    bake em for like 11-15 min, then pry apart.
  11. #471 Re: Cleans Official Retrofit Thread. Pictures of Work.
    Feb 2010
    i grabbed mine off amazon, things i learned doing my retrofit today
    1. you DO have to open up the hole or the projector wont fit in the housing
    2. patience patience patience
    3. i have a new found respect for cleangtp, if i did this multiple times i would kill myself
  12. #472 Re: Cleans Official Retrofit Thread. Pictures of Work.
    GT Level Member jmoore4294's Avatar
    In all fairness, the other 6000 ways came BEFORE someone was smart enough to use that washer.
    2004 Pontiac Grand Prix GT2 -Wizaired-DHP Tune-180° Thermostat-GMPP STB w/brackets F/R-Bilstein HD Struts w/SSC-Projector Retro-Black SPO Grilles and Spoiler-ZZP Volt. Booster & Alt Rewire
  13. #473 Re: Cleans Official Retrofit Thread. Pictures of Work.
    Feb 2010
    Yeah I tried the washer thing, wasn't working for me, so I got creative and used a pickle jar lid... worked PERFECT
  14. #474 Re: Cleans Official Retrofit Thread. Pictures of Work.
    Quote Originally Posted by OmegaRed View Post
    Do explain. That sounds interesting. I'm thinking of redoing my retro. My driver side isn't aligned correctly (apparently when you adjust the headlight up and down it rotates slightly clockwise or counterclockwise).
  15. #475 Re: Cleans Official Retrofit Thread. Pictures of Work.
    Banned
    Mansfield, Ohio
    Sorry guys I took a new job opportunity and really haven't been around much or been doing any retrofits. I'm really pressed for time to even do them anymore. I will be doing myself another set in the very near future though.
  16. #476 Re: Cleans Official Retrofit Thread. Pictures of Work.
  1. The OFFICIAL GoPro thread
    By Pkorn in forum Off Topic Discussion
    Last Post: 04-23-2013, 05:32 PM
  2. the OFFICIAL t-shirt thread
    By SilvaMan61 in forum Off Topic Discussion
    Last Post: 10-12-2011, 04:10 PM
  3. Official Wallpaper Thread
    By rocafella2032 in forum Off Topic Discussion
    Last Post: 10-30-2009, 01:07 AM
