Thread: What makes one projector better than another?
Results 1 to 13 of 13
  1. #1 What makes one projector better than another?
    Never Never Land
    I'd really like to know. With all of the projector and projector retrofit threads floating around I think we'd benefit from knowing what makes one projector better than another. By "better" I mean the intensity of the the light and the cutoffs as well as other things I may not be aware of. Info please...
  2. #2 Re: What makes one projector better than another?
    GT Level Member Tommyp2010's Avatar
    Poland, Ohio
    There's a lot of factors that go into what makes a projector better. As far as what affects projector quality, there's the shape of the reflector bowl and how reflective the chrome is. There's the spacing between the bowl, the cutoff shield, and lens which affects cutoff sharpness and color, the spacing of the bulb in the projector, the clarity and shape of the lens. A clear lens will produce a sharper and more colorful cutoff. Changing the spacing between the cutoff shield and lens affects cutoff sharpness and color. There are many other factors that infulence the quality of a projector, but these are what I can think of off the top of my head.
    The quality of the bulb and ballast makes a big difference too. An OEM bulb and ballast will outlast, and outshine a kit by miles and last YEARS longer. A kit bulb is only expected to last something like 200hrs before losing brightness and color shifting. An OEM bulb will last for thousands of hours.
    As far as what makes a projector good? That's somewhat subjective. Some people want a very smooth beam, which often isn't as bright. Some projectors have a streaky beam, but have a much more intense light. The wider a projector is, the better obviously. Some people like having a sharp cutoff, which usually isn't very colorful. Some people like having a thick colorband. The higher quality the projector, the better it will focus the light from the bulb and put the maximum amount of light on the road.
    Anything I missed?
    I'm glad to see the sudden interest in retrofits on this site, it doesn't seem to be something that's very big in the GP world, while it's huge in the Cobalt world and in many hondas and such.
    2006 Mitsubishi Evo IX MR
  3. #3 Re: What makes one projector better than another?
    Feb 2008
    Typically, an OEM projector from some random car (G35, TSX, RSX, BMW) will be of very good quality. Some come as bi-xenon, and some don't. The Morimoto projectors are decent, but do not have as nice of a beam pattern as say a FX-35 or FX-R, which have a nice, uniform, wide beam. The Mori's are, however, more compact and a hair cheaper which makes them very attractive for people like us who have very short, squatty headlights and don't want to spend $500+ doing a retro. One of the major differences between the smaller projectors and the nicer ones is the type of bulb used. The nice ones typically use a D2S bulb, where a cheaper projector usually takes a H1 or H3 size bulb.
    I put a set of FX-R's in my car and absolutely love the look and light output. It took a lot of cutting and fiberglass work to create, but well worth it IMO. With 55W ballasts and some nice, OEM bulbs, my headlights will put a new Acura or BMW's lights to shame.
  4. #4 Re: What makes one projector better than another?
    MA
    im surprised this retro revalation is coming so late. with the ****ty ass lights we got. im loving the idea...................................... and will have an extra se of headlights soon
    SMGPFC Member #9
  5. #5 Re: What makes one projector better than another?
    Poland, Ohio
    Quote Originally Posted by DanGTP View Post
    See I disagree with this. Again this is part of the subjective part. I hate the "lasers" that the FX-Rs have and the "mountain" in the middle of the FX35s. The FXs are a little brighter though. I do agree with the retro being better than the OEM setup, but that's mainly because the engineers don't spend as much time and money as they can on designing the lights. Us retrofitters have more time and less restrictions to build the best setup possible.
  6. #6 Re: What makes one projector better than another?
    Jan 1970
    Maquoketa, Iowa
    aftermarket projectors have ****ty plastic brackets that crack and break and also bounce. That is all I have to say about that.
  7. #7 Re: What makes one projector better than another?
    Feb 2008
    Quote Originally Posted by Tommyp2010 View Post
    At least we agree on 1/3 of what I said...
    But you're right. What looks 'good' is subjective. I like mine, you like yours. Either way, the light on the road is a million times better than stock.
  8. #8 Re: What makes one projector better than another?
    Poland, Ohio
    Quote Originally Posted by FoSHO99 View Post
    I bought the aftermarket OEM replacement lights to work on my retro with. I kinda hacked them up too much and am now just using them to test fit the projectors and figure out how to do it correctly. The point is, I used the brackets from those aftermarkets to replace my broken bouncing OEM ones, and they fit perfectly with 0 bounce.
  9. #9 Re: What makes one projector better than another?
    SE Level Member Lacboi's Avatar
    Jun 2010
    Atlanta
    i wish i could get these led headlights
    hids will be bye bye soon this was out way before the ls600,a8,and escalade hybrid
  10. #10 Re: What makes one projector better than another?
    Never Never Land
    eww those are gross lol...all of em.
  11. #11 Re: What makes one projector better than another?
    LED's arent exactly user replaceable most of the time....
  12. #12 Re: What makes one projector better than another?
    Donating User Odi's Avatar
    Chicago South Suburbs
    patiently awaiting for long life led's to finally reach super-high light output at a cheap price.
    http://www.tempgp.com/projects/LED/h...led_headlight/
    http://exoticcars.about.com/od/guide...-headlight.htm
  13. #13 Re: What makes one projector better than another?
    Jun 2010
    Atlanta
    funny how audi gets off saying its first lol that sts was made in 2005 and still to this day people forgot gm had nightvision first and bmw and benz gets all the fame.
    LEDs Magazine - Visteon provides LED front lighting for GM vehicle
    first to use all leds in taillights
    Cadillac Sedan de Ville - Wikipedia, the free encyclopedia
    first with nightvision
    Automotive night vision - Wikipedia, the free encyclopedia
    even dod was first by gm it says made on cien but opps way before 2001 try 1981 and yeah they couldnt get it right til last decade but my point is gm rocks(off topic but we're always off topic lol)
  1. Car makes odd howling noise
    By SDGTP99 in forum General Tech Discussion
    Last Post: 07-20-2011, 01:50 PM
  2. THIS MAKES ME ANNNNOYED!!!! very
    By KwazrollinZ28GTP in forum The Rant Forum
    Last Post: 01-01-2011, 12:50 AM
  3. What makes you laugh
    By BillBoost37 in forum Off Topic Discussion
    Last Post: 10-14-2009, 04:45 PM
  4. Who makes a nice ram air hood
    By schmitt in forum Visual/Body Modifications
    Last Post: 06-03-2009, 05:10 PM
  5. who makes this spoiler?
    By gtpinsc in forum Visual/Body Modifications
    Last Post: 02-04-2009, 04:48 PM
