Hmmmm, cant get the bi-xenon solenoid to activate in either housing. I even changed the pins in the relay harness where it connects to the headlight harness. It's plug and play it should be working I have the 9007 bi-xenon harness in the car. Wondering if it's because the relay harness only hooks to one side of headlight harness (oem blue connector from stock harness). I also have it hooked up to passenger headlight because it has to be that way because the battery is on the passenger side. All I need to do is think a minute here.........
could possibly be because the drivers side harness from factory doesn't have something connected...... I dunno, stump never had this problem before on any others. Is there a fuse for bright lights?
