Thread: retro fit
Page 3 of 6 FirstFirst 12345 ... LastLast
Results 41 to 60 of 103
  1. #41 Re: retro fit
    Banned
    Mansfield, Ohio
    Quote Originally Posted by SilvaMan61 View Post
    i dont ****ing care what your expireince is with retrofitting you dumb prick. i came into this thread to LEARN about it. which is exactly why i said go somewhere else. it isnt ****ing hard. your just a few clicks away from having your own thread in which you can whore out your work and expieriences. this thread isnt the place for it.
    You need to grow up really my friend! If it bothers you that bad don't read it nor post about it. If that's to hard for you then you must have the mentality of a 2 year old. If I had a nickel for everytime someone posted something not worthy of a particular thread I'd be rich. You wanna come in here at me with your trash mouth it's simple don't respond to me........ I'm not a little boy I'm 14 years your elder... I can promise you that you will not tell me what to do!!!!
  2. #42 Re: retro fit
    MA
    Quote Originally Posted by BoostJunki3 View Post
    which shroud looks better the transparent graphite or chrome gattling. wow they even have a ccfl halo ring option here : Bi-xenon Morimoto Mini Stage III Kit (H1) - Complete Retrofit Kits from The Retrofit Source Inc
    im going to be going the same route you are. im thinking ill go with the graphite shroud for fear of the gatling looking to ricey and flashy. does anyone know if the other shouds listed will fit well with minimal modification?
    SMGPFC Member #9
  3. #43 Re: retro fit
    Banned
    Mansfield, Ohio
    Letting you know if you think gatling shrouds are minimal modification you're mistaken. You have to hack about half of it away to get it to fit and epoxy to the projector base helps keep the shroud from coming off. You may get the e46-r's to fit decent but any of the shrouds are going to require a good amount of dremeling.
    On another note I think some graphite or gunmetal shrouds would look killer. I'm not digging the shiny chrome either really. I may go all black shroud and housing. With black corners it should look good!
  4. #44 Re: retro fit
    Florida
    The internet just exploded....
    Angry people resolved their differences and got back on track without a thread closing, or a ban..
    Thanks to both of you for putting it back on topic, and chilling out.
    I think a black shroud, with housing and corner would look most epic.
  5. #45 Re: retro fit
    MA
    Yeah i think so to. and it would be somewhat hidden, camoflaged by the housings. but still visible. but my set wont be taking off for a while
    cleangtp
    SMGPFC Member #9
  6. #46 Re: retro fit
    Banned
    Mansfield, Ohio
    I think black gtp's or gp's in general are epic. Wish that was the color of my gtp. Chrome on the front of a red car just doesn't look good imo. I had the front of my car repainted when I put the GTX hood on and the body shop matched the front bottom piece the darker gray of the rear piece where the Pontiac is. It would look good to match the shrouds that darker grey. I don't know all black is pretty tight I think.
    I don't see how anyone could get FX-R's into a gp housing really without some major dremeling. The morimotos are a tight fit themselves. The back thread on the projector housing doesn't allow for a lot of torque using the lock ring they give you if you use the nylon washer to seal the back of the housing. I use the nylon washer, usually getting the lock ring about 3 or 4 threads on. I use the 3 tipped washer they give you with the dome part fitting against the back of the headlight housing. Then fit the 1 tip washer TRS gives you against the washer dome. It locks it down considerably tighter. You have to cut the back of the housing flat with a dremel starting out though. It's a lot of finicky, tedious bs to deal with really.
  7. #47 Re: retro fit
    Donating User Odi's Avatar
    Chicago South Suburbs
    im gonna do gunmetal lower facias w/ gunmetal pregens. and a ssc drop. i personally got rid of chrome, ive seen so many balck n chrome gp's it feels a bit overdone.
  8. #48 Re: retro fit
    SE Level Member Lacboi's Avatar
    Jun 2010
    Atlanta
    started off with tsx, then sold the tsx(retroed them in a dts) so i cutup my ls430s i had in my dts(wasnt selling them since i paid $800 for them)
    added black corners, and no they are not that blue just camera phone sucked. phillips 85122 d2s of course. oh and a crown vic with homemade shrouds(a6 projectors)
    my photobucket has exceeded its bandwidth so i cant get anymore pics
  9. #49 Re: retro fit
    GT Level Member Tommyp2010's Avatar
    Poland, Ohio
    Looks nice! How did you mount them?
    2006 Mitsubishi Evo IX MR
  10. #50 Re: retro fit
    Bastard Reptile's Avatar
    Kansas City, MO
    Probably one of the first times I've ever seen this happen on a forum.
    Anywhoo...My searches for headlight housings are becoming a pain. I remember when you could pick up a pair on Ebay for $50. Now thanks to the junk projector craze, you can't even find them not paired with the corners....which I don't even need.
  11. #51 Re: retro fit
    Poland, Ohio
    Quote Originally Posted by Reptile View Post
    Plus all the aftermarket ones are a major pain to seperate. If you find actual oem ones, they're much easier to work with, but are also like $130 per side everywhere I look. You have to look at the bulb holder on the back to tell.
  12. #52 Re: retro fit
    Kansas City, MO
    Yeah, I'm thinking with the money I'd save for aftermarkets, I can deal with the issues in order to save me $150. LOL
  13. #53 Re: retro fit
    Banned
    Mansfield, Ohio
    I'm a great guy, easy to get along with but a 20 year young lad cussing and popping his mouth off at me isn't going to fly. Especially when I'm trying to help people. I can care less if I ever sell another set of retro's no skin off my back.
    With that being said you can pick up a set of stockers on ebay for roughly $60 shipped but they're not black housings. However that's not a big deal that's why they make paint. You can get black housed lights for $103 shipped on ebay just saw that today.
    If you don't want the corners or brackets I may buy them off you, always nice to have a stock pile of parts around.
    PONTIAC GRAND PRIX HEADLIGHT HEADLAMP 1997 1998 1999 LH - eBay (item 270500010206 end time Mar-06-11 11:35:48 PST)
    97 98 99 PONTIAC GRAND PRIX RIGHT HEADLIGHT NEW - eBay (item 270321120457 end time Mar-12-11 09:32:40 PST)
  14. #54 Re: retro fit
    MA
    yeah i got myself a potty mouth, always have, nothing personal. and im a good guy toooo LOL.
    headlights pop up used in classifieds all the time, most are cheap too.
    SMGPFC Member #9
  15. #55 Re: retro fit
    Minnesota
    Does anyone know where I could get just the clear plastic cover for the housing? I have a set of stockers laying around minus the clear plastic lol I think it would be sweet to try to make a set
    Open cone, SSAC headers, cat delete, 8.5 MSD wires, 3.4 zzp mps, 180*, 104's, ported blower, DHP canned tune, 19" XXR 962s, DNA springs.
  16. #56 Re: retro fit
    Banned
    Mansfield, Ohio
    Quote Originally Posted by Ricky21 View Post
    I doubt you can find just the lenses, shoot for what it's worth buy a $66 dollar set and sell brackets, corners, and bulbs. You could keep your corners and use your stock gm brackets which are much better imo, at least the adjusters.
    When I mount the Morimoto's they're level but that doesn't mean when you put them in the car they will be depending on where your adjusters are set at. The adjusters on black oem housings aren't very good.
    Just believe in yourself you can do a set of these retro's if you have some decent tools. I have the attatchment that the japs use to do nails with on my dremel. It makes getting into small places easier. Can't beat 160 piece bit kit from dremel for $29.99 at home depot. Has everything you'd ever need to do these lights.
    I will have some output pictures pretty soon, just waiting on the snow delete mod to happen. There's 3 feet of ice at my garage door right now. I recommend 880 hid fogs with morimoto's pure awesomeness!
  17. #57 Re: retro fit
    MA
    ^^ is there any specifics to that kit you mentioned? i was planning on borrowing tools as i need them but at that price ill just buy it.
    SMGPFC Member #9
  18. #58 Re: retro fit
    Minnesota
    Quote Originally Posted by cleangtp View Post
    Yea I figured I would just have to get a whole new one. A buddy of mine just got a gtp and is lookin too buy some halo projectors and I might trade mine for his stocks plus a few bucks.
    Thanks for the info, you know your s*** on thesse retros
  19. #59 Re: retro fit
    Joliet, IL
    hell yeah projectors sold pending payment and copped a free set of black housing headlights.....soon to be installed.....morimoto retrofits with graphite shrouds and morimoto 3five balasts and bulbs....
    should i go 5k or 6k? my switch backs are rated at 6k....so im thinking 6
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  20. #60 Re: retro fit
    6k. ur car is the only one i see pulling off any other light color than 4500k
  1. anyone ever try these for retro fit?
    Last Post: 02-03-2011, 10:32 PM
