Thread: high beam indicator
Results 1 to 11 of 11
  1. #1 high beam indicator
    Donating Users BoostnBlackGTP's Avatar
    Waterloo, Iowa
    ok so i got the DDM tuning 35w kit just last week and have it all installed with the relay harness and i love them.But in my HUD and on my dash my brights indicator stays on and flickers ever so often and its kinda pissin me off.I am wondering if anyone has found a fix for this at all. please let me know. thank you
    Bryant
  2. #2 Re: high beam indicator
    swift current,sask.
    Has something to do with the pin combination on the harness, there is a fix for it. You just need to switch the pins around if i'm not wrong. Its on here somewhere just too lazy to find it at the moment.
  3. #3 Re: high beam indicator
    Waterloo, Iowa
    well i dont have high beams. i got only the low beam kit
  4. #4 Re: high beam indicator
    swift current,sask.
  5. #5 Re: high beam indicator
    Waterloo, Iowa
    whiny that not like mine. i dont have highs in my hid's so therefore i noly have 2 wires coming out the side going into the ballast
  6. #6 Re: high beam indicator
    swift current,sask.
    Let me go out and take a look at mine because i only have low beams in mine too
  7. #7 Re: high beam indicator
    Waterloo, Iowa
    yea look at yours and tell me whats dff lol cuz mine r hooked up rigth for sure. they r working properly its just that high beam light. and im wondering if maybe there is someway to ground out the high beams or anything. but idk....
  8. #8 Re: high beam indicator
    GT Level Member bballa0740's Avatar
    Apr 2009
    br
    pull your cluster off 4 screws and pull the bulb....unless you mean the lights them self are flickering
    E85, Gen V, TOG Headers, 2.55 w/ SFI balancer, 3PE, Tranny, NIC Cam, 1.7 Yella Terra Rockers, LS6 springs, ...goood day sirrr ryan carter tuning
  9. #9 Re: high beam indicator
    Waterloo, Iowa
    its flickering in the HUD bballa
  10. #10 Re: high beam indicator
    Norristown, PA
    when i had a hid kit w/out hi's, i had the high beam indicator on too..
  11. #11 Re: high beam indicator
    Jersey
    i had the same thing with my gt and the 03 taurus when i owned it, both single Hid only. However i had the kit with hid lows and halogen high's and i didn't have a problem. I believe the high beam ghost illumination is indicating their is a problem with your high beam
    16' wrx sti- stock
  1. Need High Beam, Low Beam, Fog wiring help...
    By TuKoolGTP in forum General Tech Discussion
    Last Post: 12-29-2009, 12:57 PM
  2. High Beam Indicator light stays on
    By mike4567 in forum General Tech Discussion
    Last Post: 08-07-2009, 08:05 PM
  3. New HIDs installed and High Beam/Low Beam issue CORRECTED!!! Woot!
    By GeddyLee in forum General Tech Discussion
    Last Post: 01-29-2009, 07:26 PM
  4. Hid with a high beam
    By crywolf in forum Visual/Body Modifications
    Last Post: 01-27-2009, 07:13 PM
  5. 04+ DRL and High/Low beam wiring
    By ponyfool in forum Visual/Body Modifications
    Last Post: 12-01-2008, 02:31 PM
