Thread: Head light bounce
Results 1 to 17 of 17
  1. #1 Head light bounce
    SE Level Member stlunatics2oo3's Avatar
    Michigan
    okay I got a 98 GP and i replaced my stock fogged headlights with a new set of aftermarket ones and even before i replaced them they bounce but now more noticable is their a way to fix this besides like double sided tape?
  2. #2 Re: Head light bounce
    GTP Level Member SuperSport's Avatar
    Michigan
    Use the stock bracket from the old lights.
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  3. #3 Re: Head light bounce
    I live here. TLSheff's Avatar
    Not always interchangeable.
    Which set did you get?
  4. #4 Re: Head light bounce
    X2...Blazertechs are FTW.
  5. #5 Re: Head light bounce
    Michigan
    umm i dont have stock mounts and i got am auto parts on ebay
  6. #6 Re: Head light bounce
    Check local Junk Yards for some Grand Prix with the fog lights, go for the mounts, itll help when you can mount them properly.
    Just take the new ones with you and compare to see if they will fit on the stock mounts
  7. #7 Re: Head light bounce
    Michigan
    why the foglights Im very confused, my fog lights dont bounce its the head lights
  8. #8 Re: Head light bounce
    Michigan
    I replaced my fogged up head lights not the foglights those are fine
  9. #9 Re: Head light bounce
    SE Level Member Mje00GPGt's Avatar
    Anoka, MN
    I had the same problem when i bought the halos and nothing worked mounting wise i even used the stock brackets so you might just have to buy weather stripping and hide it the best you can. I know lots of GP owners have this problem with aftermarket headlights. I bought a roll at walmart for a $1 and 6 months later its still holding up and you cant tell its there
  10. #10 Re: Head light bounce
    Michigan
    thanks for the idea
  11. #11 Re: Head light bounce
    Ocala, FL
    Projectors? If so, I have another question. Are your beams shooting perfectly flat? If not, they're aimed wrong as well, which is likely with those headlights. It is repairable though.
    I would start by taking a zip tie to each side to pull the back side of the headlight into the car slightly more, if you have the spyder auto ones they probably stick out a tad. This will pull the aim in a little, and possibly a little higher, for the rest, I'd recommend putting foam weather stripping underneath the headlights. Maybe different on another car, but my car being black, you can't even see it.
    If they aren't the spyder autos, the zip ties may not be necessary, but the weather stripping is still the best way to go to completely eliminate the bounce.
    If you don't quite understand what I mean let me know and I'll snap a pic or two.
  12. #12 Re: Head light bounce
    Michigan
    mine are regular lights
  13. #13 Re: Head light bounce
    Jul 2008
    sumter,south carolina
    i had this issue with my halos... if they packed ur lights in the really squishy foam, take some of that and put it under the bumper skin where the head light sits. this helped alone by itself. but then i took my lights out and wrapped electrical tape all around the plastic clips that hold the light to the bracket... pop them all way out. mine popped out easy... wrap that piece 2 or 3 times in tape, put the piece back in then wrap the the plastic piece and where it clips into the bracket with as much tape as u want. mine turned out good and u cant really see the tape when lights are installed. i have no bounce at all even when i hit bad bumps in the road.
    02 GTP with mods 05 GP for DD
  14. #14 Re: Head light bounce
    Jul 2008
    i also used foam rubber double sided tape to make them fit better... it helped with bounce alot... i got it at lowes. they have a bunch u just gotta get the stuff that feels soft. ive had to replace foam twice in a year though.
  15. #15 Re: Head light bounce
    Donating User Odi's Avatar
    Chicago South Suburbs
    ^^ you can also use weatherstriping, should last longer too.
  16. #16 Re: Head light bounce
    Dec 2008
    Lawndale, CA
    There was a athread many years ago on club gp about limiting the bouncing on a set of stock headlights. This is the one.
    ClubGP Message Forum troubleshooting
  17. #17 Re: Head light bounce
    Denver
    This fixed mine:
    I just reinforced some of the loose mounts on the assembly - nothing on the outside.
  1. Head light restoration
    By kolman in forum How To Write-Ups/Tech Tips
    Last Post: 05-02-2010, 03:35 PM
  2. Head light going dim, what should I get now?
    By cojo in forum Visual/Body Modifications
    Last Post: 04-03-2009, 01:36 PM
  3. head light failure
    By kamikaze275 in forum General Tech Discussion
    Last Post: 01-25-2009, 03:46 AM
  4. Head Light/Tail Light Covers
    By datApocalypse in forum Visual/Body Modifications
    Last Post: 01-30-2008, 11:38 PM
