Thread: Water/Moisture on Inside of Tail light
Results 1 to 13 of 13
  1. #1 Water/Moisture on Inside of Tail light
    GT Level Member Egleone6's Avatar
    Springfield, Illinois, United States
    I know I need to replace this, but I am looking at a used one, is there a way to tell if the used one is any better than the one I have?
    Or is there a way to fix the one I have?
  2. #2 Re: Water/Moisture on Inside of Tail light
    Louisville, KY
    Look for cracks in the back and reseal over existing seal.
    Find new washers to replace the worn ones on the lights.
    If you've got a crack on the back use sealant to cover it; if it's on the front sand the whole taillight, tint with nightshades and then take to an automotive paint shop and have clear sprayed. That will hide the crack and the clear should seal the leak.
    My Cardomain
  3. #3 Re: Water/Moisture on Inside of Tail light
    Any easy ways of getting the middle screw out? Or do you have to undo the bolts that attach with the netting in the trunk?
    If my pics are not working, please email me, I may have moved the pics on a different page on Photobucket. Thanks
  4. #4 Re: Water/Moisture on Inside of Tail light
    Here is the pic of my tail and the plastic piece that may be the cause and the insert bolt that may have to be removed. In the second photo, what is that plastic part called? I need a new one and cant find one on the GM Parts list.
  5. #5 Re: Water/Moisture on Inside of Tail light
    Well I got around to looking at what is my problem. It appears that the plastic piece that fits flat is the problem. Pic 3 is the problem I think. I took all 3 of the bolts/wingnuts off and all three bulbs and about a 1/2 - 3/4 cup of water came pouring out. None from the bulb area, just from the area in front of the bulb. btw, the water was quite warm. I am letting it sit in the sun, I will try to rig it somehow, but knowing that I will have to probably buy a used one.
    Any other ideas? I was thinking of putting some auto sealant over the plastic piece as I get it all secured.
  6. #6 Re: Water/Moisture on Inside of Tail light
    Louisville, KY
    I'd go to autozone and get glue all and reseal the spot and then add some extra around the outside edge of the crack. Wait and see if it returns.
    My Cardomain
  7. #7 Re: Water/Moisture on Inside of Tail light
    May 2008
    that is exactly how my tail light looks. i know where the water is and what i need to do to fix it, i just need to know how to get the outer most clear plastic piece off so i can clean that off.
  8. #8 Re: Water/Moisture on Inside of Tail light
    Louisville, KY
    Coat hanger with a papertowel wrapped around it and taped off so it doesn't fall off inside.
    My Cardomain
  9. #9 Re: Water/Moisture on Inside of Tail light
    Louisville, KY
    If that doesn't work then use the old swimmers ear trick. Take it off the car, dry what you can, pour some rubbing alcohol inside, swish around to break up water spots, sit in sun so water and alcohol can evaporate.
    My Cardomain
  10. Thanks jammy thanked for this post
    Likes jammy liked this post
  11. #10 Re: Water/Moisture on Inside of Tail light
    SE Level Member nathan kilburn's Avatar
    Jul 2008
    georgia
    i just took it off and used a blow dryer and dried the mess out of the moisture and then sealed the cracks so no more mositure
  12. Thanks jammy thanked for this post
  13. #11 Re: Water/Moisture on Inside of Tail light
    MD
    Gonna try the same. Mine have exactly the same problem - 1999 GP.
  14. #12 Re: Water/Moisture on Inside of Tail light
    GT Level Member Pursell1911's Avatar
    Jan 2017
    Louisville, Kentucky
    lol, resurrecting the 10 year old post! Nice!
    2006 Grand Prix GT - 3" Downpipe | DIY Intake
  15. #13 Re: Water/Moisture on Inside of Tail light
    MD
    Quote Originally Posted by nathan kilburn View Post
    I tried all the suggested tricks. Nothing worked. The water is dried out, but now the clear outer shell is cloudy and white in some spots. I also notice a lot of cracks on the top part of the lens. I gave up and ordered new LED ones from RockAuto. BTW, the LEDs are only for the turn/brake lamps. The backup and running lights still use the original incandescent bulbs. So they say in the comments on Amazon.
  1. where to get tail light cover decal
    By Sinister Drag Designs in forum Chevrolet Impala
    Last Post: 07-28-2016, 10:23 PM
  2. Moisture in Headlights
    By Dohner in forum Visual/Body Modifications
    Last Post: 02-19-2008, 01:39 AM
  3. Head Light/Tail Light Covers
    By datApocalypse in forum Visual/Body Modifications
    Last Post: 01-30-2008, 11:38 PM
