Thread: LED brake light strip
Results 1 to 6 of 6
  1. #1 LED brake light strip
    SE Level Member MakeitLouder97's Avatar
    Maryland
    i looking to install a Led brake light strip i have two 12" that im trying wire to the turn signals and when the brake pedal is pressed i know i can tap into one of the brake light balbs but there are 3 wires A B and G well G is ground but which is the wire for brake and turnsig can any one help
  2. #2 Re: LED brake light strip
    I live here. TLSheff's Avatar
    http://www.grandprixforums.net/4th-b...klid-5152.html
    Maybe something like this will help
  3. #3 Re: LED brake light strip
    Maryland
    thats just wire it to the brake light i want to also want to be able to use the turnsigs also
  4. #4 Re: LED brake light strip
    they make them like this already, you just have to wire it up correctly.
  5. #5 Re: LED brake light strip
    Rockford, IL
    I have the 12" strips hooked up to mine. The green and yellow wires are the brake/turn line. Green is passenger side and yellow is the driver side.
  6. #6 Re: LED brake light strip
    Maryland
    Hey man thanks a lot i was just about to start randomly splicing in to them
  1. Trac off light, Brake light on?
    By 1badregal in forum Brakes/Suspension/Chassis
    Last Post: 10-17-2010, 10:24 AM
  2. Water in LR brake light housing/ABS light
    By andante147 in forum General Tech Discussion
    Last Post: 05-31-2010, 08:01 PM
  3. e-brake light
    By PNIGZ in forum Brakes/Suspension/Chassis
    Last Post: 02-26-2010, 06:12 PM
  4. my 4th brake light and 3rd reverse light
    By HART in forum Visual/Body Modifications
    Last Post: 11-05-2009, 01:33 PM
  5. Third Brake Light & LED's
    By Metallistar in forum Audio, Security & Visual Electronics
    Last Post: 05-29-2009, 11:06 PM
